monster reem Posted July 13, 2012 Share Posted July 13, 2012 Hey guys i am looking for a 1mm Performance head gasket for my 76 280z L28E with a N42 head if you have on please let me know. text or call me at 8456996251. Quote Link to comment Share on other sites More sharing options...
Josh280z Posted July 13, 2012 Share Posted July 13, 2012 felpro.... Quote Link to comment Share on other sites More sharing options...
tyler031734 Posted July 13, 2012 Share Posted July 13, 2012 felpro.... +1 Holds my 10PSI on a F54 and P90 Quote Link to comment Share on other sites More sharing options...
roger280zx Posted July 13, 2012 Share Posted July 13, 2012 25 bucks at autozone Quote Link to comment Share on other sites More sharing options...
monster reem Posted July 14, 2012 Author Share Posted July 14, 2012 No i need it for my n/a build i have to bump compression. I need a 1.0mm gasket. Does anyone have one? Quote Link to comment Share on other sites More sharing options...
Lazeum Posted July 14, 2012 Share Posted July 14, 2012 If you keep it n/a, Felpro gasket is enough. I'm running L28 planned to push around 250 crank HP, I've got a felpro gasket. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 14, 2012 Share Posted July 14, 2012 Isn't stock 1.25 mm? 1.0 isn't much of a bump, is it? About 0.2 increase for a stock L28. Quote Link to comment Share on other sites More sharing options...
Lazeum Posted July 15, 2012 Share Posted July 15, 2012 (edited) Stock & Felpro are 1.0mm thick compressed. I've measured both during my engine rebuild. You should not use gasket thickness as an option to bump the compression ratio. You should use your head, your block & pistons/rods for this. I have machined the top of my pistons to match my setup: block resurfaced, milled P79 head & flat top pistons. Edited July 15, 2012 by Lazeum Quote Link to comment Share on other sites More sharing options...
monster reem Posted July 16, 2012 Author Share Posted July 16, 2012 Well I wanted to get the head gasket from z car motorsports but there performance gasket is 300 bucks so I was wondering if anyone had a one or two mm performance gasket cheaper. I have a rebuilt n42 head so I wouldn't bump compression up to much bc my head is alil under spec so it would put it back within its limit. Quote Link to comment Share on other sites More sharing options...
Zmanco Posted July 16, 2012 Share Posted July 16, 2012 Why are you not considering the Felpro? Quote Link to comment Share on other sites More sharing options...
Josh280z Posted July 16, 2012 Share Posted July 16, 2012 Felpro has been used for MANY years... It is a reliable gasket if everything is installed properly and nothing is warped. You will be fine. Quote Link to comment Share on other sites More sharing options...
