theczechone Posted August 11, 2012 Share Posted August 11, 2012 (edited) I need some help, I am looking to buy an already assembled L31 long block and have a few pics from the guy, and there seems to be some corrosion on the coolant passage ways. I am not sure which are the oil passage ways, could you please look at the pics and tell me if the corrosion is "acceptable"? The block has been built about a year and a half ago and has been sitting in storage under cover since. My last 280 had a stroker and I loved it so I really want to build one again. anyway here are some pics, tell me if you think it's worth the while. Edited August 13, 2012 by theczechone Quote Link to comment Share on other sites More sharing options...
rossman Posted August 12, 2012 Share Posted August 12, 2012 I wouldn't worry so much about the corrosion in the water jackets as I would the scoring marks in cylinder #5. I can only see #5 but it probably has the same problem in the other cylinders not shown. Who built the engine? Does he have any documentation on the build? How do you know it's really a stroker engine? I would be leery of purchasing this engine. How much does he want for it? BTW, your first and second pictures are too small to be or any use. Quote Link to comment Share on other sites More sharing options...
mark Posted August 12, 2012 Share Posted August 12, 2012 Does the stamp on the piston that says STD mean it is a piston for a stock bore? Quote Link to comment Share on other sites More sharing options...
cockerstar Posted August 12, 2012 Share Posted August 12, 2012 (edited) Likely stock bore for a ka24de or one of the other engines that have the right bore/appropriate pin height for a stroker. Edited August 12, 2012 by cockerstar Quote Link to comment Share on other sites More sharing options...
duragg Posted August 12, 2012 Share Posted August 12, 2012 Specs are listed in the for sale section. I took a good hard look at it, but its right there at the cost of parts-ish (700 crank, 100 F54, 100 rods, 250 pistons?, bearings, etc. machining). I think at the very least check all the clearances you can. Or ideally pull apart and check everything and use it as a super collection of parts. I doubt it will sit around for very long in the F/S section. Quote Link to comment Share on other sites More sharing options...
steve260z Posted August 12, 2012 Share Posted August 12, 2012 (edited) Reload those other pics. Edited August 12, 2012 by steve260z Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 12, 2012 Author Share Posted August 12, 2012 I am not currently near my computer, I'll try to repost pics as soon as I can. I didn't realize there was a f/s add for it on here. I found it on Craigslist. Also the engine is in California, I'm in Michigan so there will be a high cost of shipping in this for me. I am set on a stroker motor thou and I thought that combined this could be a good way to start. I am weary because I can't inspect the engine in person. Perhaps you can see better than me, but I did not notice any scoring, could you please elaborate. Thank you Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 13, 2012 Author Share Posted August 13, 2012 I think I see the score on the cylinder and that could definitely be a problem. His asking price is 1200 and it would cost me right around 400 to ship. Quote Link to comment Share on other sites More sharing options...
kaito Posted August 13, 2012 Share Posted August 13, 2012 Im actually local to this motor. I can take a look at it if you want me to. Its posted on san diego c/l right now. Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 13, 2012 Author Share Posted August 13, 2012 Hi, that would be great, I'd like to check for the crank end to end play, check for any scoring on the cylinder walls as was pointed out, and really just anything that looks out of place. If possible measure piston/deck height (how much the piston sticks out of the cylinder block). Again this would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
