logan1 Posted September 21, 2012 Share Posted September 21, 2012 I am running a SBC 355 with a 600 cfm Holley and am using a GP-4070 Carter competition series fuel pump with a Holley pressure regulator. Can i just cap the OEM return fuel line or do i need to actually run a return line? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 21, 2012 Share Posted September 21, 2012 Yes you can cap it. Do not need a return line for that pump. How ever if you do run a return line it will make the pump run cooler. From what I was reading max fuel press for this pump is 6lbs. John Quote Link to comment Share on other sites More sharing options...
logan1 Posted September 24, 2012 Author Share Posted September 24, 2012 thanx I'll go ahead and run a return line...sounds like it would extend the life of my pump. Quote Link to comment Share on other sites More sharing options...
gravityflyer Posted September 25, 2012 Share Posted September 25, 2012 Incidentally, the latest episode of Muscle Car briefly mentioned the need for a return line in terms of vapor lock: http://www.powerblocktv.com/player/show_player.php?ep_num=MC2012-14&ep_show=MC Quote Link to comment Share on other sites More sharing options...
Scarab73 Posted September 30, 2012 Share Posted September 30, 2012 Hi, I've heard this too about the use of a return line to reduce the tendency for vapor lock. However, wouldn't a carb spacer aid in this and be a simple fix, that is, if this is the goal? Quote Link to comment Share on other sites More sharing options...
Pyro Posted October 6, 2012 Share Posted October 6, 2012 I recommend you change your whole fuel system. I have gone down the path of aftermarket carb pumps and have came across a better solution during my last V8 conversion. I would use the stock efi fuel pump (or like stock efi msd 2225) and an Aeromotive return style fuel pressure regulator set to 6 psi. The stock efi pumps are quiet and very durable and flow a lot of fuel, especially at 6 psi. After market carb fuel pumps are LOUD and don't last long (brushes wear out). Quote Link to comment Share on other sites More sharing options...
