Seals for Bosch 044 fuel pump inlet?
DuoWing
I've been using a bosch 044 inline fuel pump in my attempt to get a quieter pump and get rid of my fuel problems. One issue I can't seem to get rid of is the fact that I cannot get it to seal on the inlet. I ordered the metric to hose barb adapters for the pump. The inlet is 18mm x 1.25 I believe. Anyway it came with an aluminum washer that I cannot seem to get to seal. I tried an o-ring that came with the 18mm x 1.5 oil drain plug from the auto parts store. This seemed to work, but is already leaking as I think it's deteriorating. My outlet is fine, but I'm using the brass/copper or whatever it was crush washer that the pump came with. Anyone have any suggestions where I can get a washer/ring/seal that will work? Should the aluminum one work, maybe I'm not tightening it enough?
