L26 spark only, COP
winstonusmc
Just wanted to show it off.
Just start the L26 for the first time on Megasquirt. Specs are:
L26
MS3/3x
Ford Mustang COP running 2.0ms dwell
Nissan 6 channel igniter
82 L28ET distributer running the DIY trigger wheel
Zietronix type MAP sensor (50psi)
Right now its just idling good. Havent made a good ignition map yet, just running 15 degrees static right now.
I just need a better timing curve.
SOOOO awesome!!! You should be able to make a pretty agressive ignition map with it carbbed N/A like that. I would throw a big lumpy cam on it and rev it to the moon with that setup! Btw, if you make a cover for the dizzy I would be interested in seeing the end result.
  • 3 weeks later...
Hello,
That's really cool.
Could you give me a list of parts that are required to setup something like this?
I am currently running MS fuel only and I want to upgrade to something similar to your setup.
If I can avoid using a 36-1 wheel on the crank pulley and use the distributor as my trigger that would be nice.
I guess I need a 280ZXT distributor because the trigger wheel will not fit correctly in my 280Z dizzy.
It seems to be much bigger than the ZXT dizzy, it looks like it is 70mm diam. compared to the 54mm.
Would COP from 6 cylinder BMWcompatible with this kind of setup, it is easier to get in Europe than Ford.
One more thing, what did you exactly do to swap the dizzy?
Did you drop the oil pump or did you just swap the bottom end of the dizzy?
Let me know
Thanks
Edited by 2s2mad
i have driven it a lot since the swap and it is running pretty well. i have added a little more advance to make some good power too.
as far as the parts required, they are listed up innthe first post. the oil pump drive had to be changed. it was dropped out the bottom wit the oil pump removed. i used the ford coils as the bracket i have was made for them. they are quite easily souced in th US and very cheap. i payed $60 for 8. you can use whatever coils you wish as long as you cannget themmto bolt up.
as i said before, i am using the DIY trigger wheel that acts like a 12-1 crank wheel with a single cam trigger.
  • 3 weeks later...
Hello,
I have gathered some parts to build my wasted COP ignition.
But could you tell me how you wired all this exactly?
The BMW COP were too heavy and bulky (old design with 3 wires) so I got some 2 wires COP.
I am not sure about how to wire the COP (+12V, ground...)?
There is no permanent 12V with these like with the BMW COP which have permanent 12V, Ground and Trigger.
Can you describe how they are connected to the Nissan igniter?
Did you use a DIS6-02 from a 300ZX?
I made a little drawing, is that correct?
Thanks
Cheers
Hello,
Thanks for the drawing  I would have never though about wiring it that way.
I have one concern though, it seems that EDIS is grounding the coils.
Isn't the 300ZX igniter sending +12V instead?
Thanks
Cheers
Simon
Edited by 2s2mad
  • 1 month later...
