troubledz Posted November 27, 2012 Share Posted November 27, 2012 Hey All, I just purchased a F54 block with a E31 head on it complete from a member on this site. I have a few questions to ask and hopefully get a few answers? This engine was rebuilt in the early 2000's it has a remanufactured engine sticker on it. made in Japan ...This was done by the Z doctor,It is a F54 block and it looks to have dished pistons in it from looking down the spark plug hole. My thoughts is that his combo will not work unless the E31 head had a lot of work to it. The CR would be ??? I have read a lot about F54 with flat tops but why would they put this head on with dished pistons? the PO said the motor ran strong. and it must have. it was rebuilt in the early 2000's and driven. Is there a way to tell if the head had any work done to it without taking it off? i.e.: larger valves?? I just purchased a set of triple Weber’s for it and want to figure out if it will have enough CR to support this set up? I would love to save some $ if I did not have to tear the whole engine down, it looks to be in really good shape. Thanks Guy's, Dean Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted November 27, 2012 Share Posted November 27, 2012 http://atlanticz.ca/zclub/techtips/calcs/engine%20builder/index.html This may not be 100% accurate, but close enough for me. You should have around an 8.7 c/r. Which is basically normal. F54's did come with dished pistons in the 81-83 turbo 280zx's. As for work on the head, you would need to take it off for valves and chambers, but you can see if they did any porting or a cam, and even if they shaved it by measuring the height of it. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted November 27, 2012 Share Posted November 27, 2012 Sounds like a great turbo motor, but you might have to mod the head for fuel injection. Quote Link to comment Share on other sites More sharing options...
