rickyellow zee Posted April 7, 2013 Share Posted April 7, 2013 Are there any differences between the 280zx turbo and 280zx NA throttle bodies within the same year? I need a throttlebody for my L28ET and a local guy is selling one from the NA L28ET. Quote Link to comment Share on other sites More sharing options...
PredatorZ Posted April 7, 2013 Share Posted April 7, 2013 pretty sure the parts would be interchangable, throttle body swaps using 60mm 240sx parts works with a little fabing. Typo I thing when you put "NA L28ET", Can't be both Good luck Quote Link to comment Share on other sites More sharing options...
stravi757 Posted April 7, 2013 Share Posted April 7, 2013 Are there any differences between the 280zx turbo and 280zx NA throttle bodies within the same year? I need a throttlebody for my L28ET and a local guy is selling one from the NA L28ET. yes they are different. the trubo Throttle body does no have a bypass for idle. Quote Link to comment Share on other sites More sharing options...
WreZ Posted April 22, 2013 Share Posted April 22, 2013 I also think that theres a difference with the throttle position sensor, then again I might just be remembering wrong Quote Link to comment Share on other sites More sharing options...
jeffp Posted April 29, 2013 Share Posted April 29, 2013 theyare different, but that is not to say you cant make it work. If I were in you place, Iwould just do the 60mm TB upgrade. Arizona zcar has the adapter for about 45 USD and you can source the TB easily enough. Good upgrade, and that should be all you will ever need, well unless you want to run more then 600hp. Quote Link to comment Share on other sites More sharing options...
