Throttlebody differences(280ZX)
Are there any differences between the 280zx turbo and 280zx NA throttle bodies within the same year? I need a throttlebody for my L28ET and a local guy is selling one from the NA L28ET.
 yes they are different. the trubo Throttle body does no have a bypass for idle.
  • 3 weeks later...
theyare different, but that is not to say you cant make it work. If I were in you place, Iwould just do the 60mm TB upgrade. Arizona zcar has the adapter for about 45 USD and you can source the TB easily enough. Good upgrade, and that should be all you will ever need, well unless you want to run more then 600hp.
