Bohdan Posted April 30, 2013 Share Posted April 30, 2013 Hello everyone, I am building a RB25 260z, planning to make some high numbers (around 600-700hp) and I heard somewhere that the huns on those cars are weak and dangerous if they break. So i was wondering how much power can the hubs really take before the wheel goes flying away? and is it true that they are weak? Any input would be appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 30, 2013 Share Posted April 30, 2013 Search "chromoly stub axles". Quote Link to comment Share on other sites More sharing options...
ktm Posted April 30, 2013 Share Posted April 30, 2013 It's not horsepower that breaks things it's torque. Your RB might put out 600 hp but only 400 tq. Many of us are running that much torque in our LS1s (and old L28ETs). Quote Link to comment Share on other sites More sharing options...
Bohdan Posted April 30, 2013 Author Share Posted April 30, 2013 It's not horsepower that breaks things it's torque. Your RB might put out 600 hp but only 400 tq. Many of us are running that much torque in our LS1s (and old L28ETs). with the OEM hubs? Quote Link to comment Share on other sites More sharing options...
gnosez Posted May 2, 2013 Share Posted May 2, 2013 280 stub axles Quote Link to comment Share on other sites More sharing options...
Bohdan Posted May 2, 2013 Author Share Posted May 2, 2013 280 stub axles Im not going to run the original Diff. If you are referring to the stub axles that slide into the differential. I am going the FORD 8.8 diff with drive shaft shop axles. but its the hubs that i am worried about. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 2, 2013 Share Posted May 2, 2013 The hub is the part of the strut that the bearings fit into. The stub axle is the part that goes through the hub. The DSS axles fit up to stock stub axles, at least the ones that I've seen do. You need to look at upgrading the stub axles. So again, search "chromoly stub axles" and you'll find what you need. Quote Link to comment Share on other sites More sharing options...
