mattb3562 Posted May 19, 2013 Share Posted May 19, 2013 The two most popular schematics that I've found on wiring the stock 82 dizzy to MS1v3 is as shown...but what I have coming out of the distributor is a white, black, green, and red wires. I bought the DIY harness with the twisted pair coming off of pin 24. Can anyone tell me exactly which wires connect to the dizzy? I think the red will go to 12v switched...white to white (out of the pair) with an inline 1k resistor and then tied to my red 12v wire. Does black wire out of the twisted pair connect to black on dizzy or with the white? I've run a seperate ground for the dizzy to go to chassis ground. Thanks in advance for the clarification. Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted May 20, 2013 Author Share Posted May 20, 2013 Sorry, I was in a fizz and forgot to insert the pics. Here's the diagrams that I was referring to...I'm sorry if this is a dumb question, but this part, I can't seem to put two and two together. Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted May 20, 2013 Author Share Posted May 20, 2013 Also, after doing some more digging, the fsm shows the colors on Moby's writeup to be right and mine to be other than factory. Maybe a replacement, I don't know. This guy had the same problem in 2005, that a few chimed in on,but doesn't show what came of it. Does this one ring a bell to anyone? ...Tony?... Help? http://www.zcar.com/forum/10-70-83-tech-discussion-forum/105372-82-cas-sensor-wiring-megasquirt.html Quote Link to comment Share on other sites More sharing options...
loy Posted May 20, 2013 Share Posted May 20, 2013 http://forums.hybridz.org/topic/77165-82-83-l28et-distributor-plug-pics-please/ Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 20, 2013 Share Posted May 20, 2013 loy makes a point, indirectly. You can look at the position of the wire in the connector plug to convert your colors to the diagram colors. There's a drawing of the plug in the 1982 FSM, Electrical chapter, EL-32. Quote Link to comment Share on other sites More sharing options...
loy Posted May 20, 2013 Share Posted May 20, 2013 Also in the MS harness use the white as signal. The shielding should be grounded. The other wire is not needed. Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted May 20, 2013 Author Share Posted May 20, 2013 So.....just to be absolutely sure....I can run a 12v supply to red White wire out of shielded pair to white Solder in 1k in the white wire and tie back into red And tie black wire from dizzy to shielding and run both to chassis ground? All this and not use black wire in twisted pair or green from dizzy? I really appreciate the help fellas, as I just wanna do it right before any major woes occur. Lol Quote Link to comment Share on other sites More sharing options...
