Guest Anonymous Posted March 5, 2002 Share Posted March 5, 2002 Anyone out there have any experiences working with Arizona Z? I am considering the purchase of his rust-free 8/73 260Z. I am also considering Dave's full road race suspension system and having him build a L28 T3 hybrid turbo with Dave-Jection fuel injection control system. How does that suspension run on the street? I have heard it is rough due to the spherical bearings? Any experiences with the Dave-Jection system?? Also any comments on the need for the damper pully? Do you think this is a good setup for a strong street car? Here is a parts list. 8/73 Z-CAR $1650 COMPLETE ROADRACE SUSPENSION WITH BRAKES $5200 R-200 4.38 LSD $750 CLUTCH KIT $99 STEEL FLYWHEEL $279 TURBO OIL-PUMP $49 ALUM. OIL-PAN $375 ALUM. RADIATOR $349 BILLET PULLY SET $299 NEW CON-RODS $120 dished PISTONS .040 over $220 BODY KIT: F&R GT BUMPERS, SKIRTS, WHALETAIL $800 IGN. MODULE $79 TURBO COIL $21 REUPHOLSTORY KIT $169 RUBBER SEAL KIT $249 SWAY-BAR KIT $279 L-28 BLOCK $225 TURBO EXHAUST MANIFOLD $125 P-90 HEAD $225 NON-EMISSION INTAKE $75 TURBO INJECTORS $350/SET INJECTION PUMP $169* HYBRID TURBO $650 5 SPD TRANS $250 FUEL-INJECTION CONTROL UNIT (DAVE-JECTION) $469 REBUILD BLOCK & HEAD APPROX $500-$600* PARTIAL PROJECT ASSEMBLY IF REQUIRED $?* I WILL INCLUDE RACK BUSHINGS, STEERING COUPLER, MUST. BAR, DIFF MOUNT, MUSTACHE BAR BUSH., REAR A-ARM BUSH., and TRANS-MOUNT BUSH(IF POSSIBLE) WILL ALSO INCLUDE AIR CLEANER TOTAL AS LISTED = $13775 PACKAGE WITH ABOVE ITEMS $13500 Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 5, 2002 Share Posted March 5, 2002 skip the "dave jection" and go SDS. use a 240sx Tbody- i have one for $80 between Mike Kelly here and myself you can get the equivalent suspension and brakes for a LOT less the car and the diff are good prices but the rest?????????? Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted March 5, 2002 Share Posted March 5, 2002 Lawrence, ditto what scca said about the SDS and suspension/brakes. In addition, I have some observations that I find a little troubling. - You do not want a 4.38:1 diff with a turbo. Understandable maybe if there was a hairy cam and other things to support high RPMs, but that is N/A mentality. - I question $279 for a steel flywhel but only $99 for a clutch kit. That has to be backwards, else you will be changing out that cllutch in a week. Find a good stock 240mm flywhel and have it turned and invest in a top quality clutch kit. - Aluminum oil pan, $375. Put that money into something KEY like a top-quality I/C, DP and 3" exhaust - If you building a strong turbo engine, what pistons are you getting for only $220 and why +.040? Good luck, but there are lots of folks on here who have been that route and can really help guide you to the best setup. We enjoy spending other people's money Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted March 6, 2002 Share Posted March 6, 2002 I believe I have the AZZcar suspension on my '77 280Z. I don't know for sure, since it was on the car when I bought it, but, looking at the pics, it looks identical to what I have on there now... At first I thought the ride was a little too stiff for my taste (and that was coming from a 2" lowered DSM), but after having owned it for a month I've come to appreciate the suspension a bit more and have decided against replacing it with a more of a stock type suspension. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 6, 2002 Share Posted March 6, 2002 1st off let me say that the Arizona Zcar suspension parts are BOMB PROOF Chromoly steel units and they are well engineered. The ONLY complaint anyone has ever had about them is that they are a PITA to setup on a machine or at the track. You must unbolt each heim joint pickup point to adjust it for alignment, which can take some serious time and money (On an alignment rack or in the pits). If you already have them, my advice is to keep them. If you don't, then look at other alternatives! Mike Kelly Quote Link to comment Share on other sites More sharing options...
stony Posted March 6, 2002 Share Posted March 6, 2002 I can say from experience dave is very trust worthy. i have his radiator, coilover kit, chromoly arms, The only thing i didnt like was the front arms require drilling of the engine member for bigger arm bolts. the TC rod also have no bushings so it makes for a loud and rough ride. I dont think there is any weight reduction in using his arms but they have to be stronger. and they look so racey. stony Quote Link to comment Share on other sites More sharing options...
Guest ShelbyZ Posted March 6, 2002 Share Posted March 6, 2002 I am guessing the steel flywheel you are talking about is the "lightened" flywheel. A friend of mine bought the lightened steel flywheel and has no complaints. He did have to take it to a machine shop and have it turned. I think machine work was about $30. I have the Centerforce flywheel from MSA and have no complaints. Another friend just bought a flywheel from Fidanza. It weighs like 9lbs. He hasn't installed it yet, but it sure looks pretty sitting in the box. Keep ZZZZZZing ShelbyZ Quote Link to comment Share on other sites More sharing options...
