LS1 Up Date info
How is the LS1 conversion on your Z holding up, miles since the conversion , any issues, info relevant to the up keep, developments on the built  :icon5:  Here is my up to date  info on my Z with an LS1 engine. Over 25K miles since conversion(2005)10K by PO the rest on me in over a yr.  Engine is stock, oil changes using Mobil 1, one resent issue with the engine coolant sensor. Up keep maintenance ; rear differential mount needed re enforcement ,  brake booster replaced, front and rear pads replaced,new aluminum radiator, new set of tires, battery replaced and the A/C compressor was acting up and was replaced last summer. The T5/6spd and Q45 R200 diff has no issues   She is a joy to ride, reliable, ease of maintenance, plenty HP, close to 30mpg's, best of both worlds,Old Nippon Classic GT with modern engine/suspension/brakes post-36683-0-34109800-1374083235_thumb.jpg   :icon12:
Edited by PLATA
78 Z was done in Jan 13 , has about 500 miles . Broke front diff mount , converted to RT diff mount . Now I have to redo my motor/trans mounts , RT diff mount threw drivetrain angle off a little ( vibration ) .
83 was done about 2 or 3 yrs ago , rear diff is clunking . Will be converting to solid axle once the turbo 6.0 is built .
My modified diff mount developed  a crack due to metal fatigue post-36683-0-24816900-1374116862_thumb.jpg,post-36683-0-24152200-1374115534_thumb.jpg crack was welded and back on the road post-36683-0-19327800-1374115578_thumb.jpgpost-36683-0-74456500-1374115603_thumb.jpg stump re adjusted to prevent play post-36683-0-58476400-1374115641_thumb.jpg post-36683-0-40457700-1374115668_thumb.jpg Q45 R200 diff modified axles, no issues since the weld fix     :icon12:
Edited by PLATA
 More  update info on my beast >>>post-36683-0-30662400-1374172337_thumb.jpg picture taken at the Z convention in 2007. This one taken last week >>>post-36683-0-37138300-1374172449_thumb.jpg she stills shines and flys,  engine pic then>>>post-36683-0-94339000-1374175569_thumb.jpg now>>>post-36683-0-79422700-1374175731_thumb.jpg. Cabin then>>>post-36683-0-67845800-1374175800_thumb.jpg now>>>post-36683-0-38351000-1374175877_thumb.jpg There is not a day that I don't get a complement, David the PO went all out in her creation plus the Cali owner who commended the restoration back in 1997 did a fantastic first rate job on her>>>post-36683-0-31336200-1374173001_thumb.jpgpost-36683-0-77632700-1374173074_thumb.jpg My addiction to this Z is non reversal. This site generates more to the illness , the know how plus the vast info found here makes this vice a JOY  :icon12:
Edited by PLATA
The intent/purpose of this thread is to update members with information on LS1 Z conversions. I as an owner of one would like to know on any improvements that can enhance the performance( suspension,exhaust,brakes, transmission / differential, electrical components/ECU ),reliability,latest on maintenance tips , overall upkeep on a Z and the developments on the built. It come as a surprise that less than five site members have shared their info, if this is a duplicate thread please link it  or if this a worthless topic delete it    :windows:
Edited by PLATA
I appreciate your effort of sharing information. I for one will be doing a conversion in about a year and been saving and documenting information as I find relevant to my LS1 conversion. I find some of the headaches and fixes of others interesting in seeing the cause and solutions if I ever run into them.
Thanks again!!
I have 34,000 miles on my conversion so far with the following issues:
1. Infant mortality on the relays for my stock Z28 donor cooling fans. Replaced both and no issues in last 10 years.
2. Burned through a lead to my starter. Relocated it further from the exhaust header. No issues in last 8 years.
3. Smoked my front brakes while racing at Texas Motor Speedway. Replaced front brakes with Willwood 4 piston calipers on 12.2" vented rotors and rears with the 240SX calipers on 11.4" 300ZX rotors. Still need to add the adjustable pro portioning valve but otherwise no issues in 9 years.
4. Broke a half-shaft universal joint on a 1-2 shift at a track which took out my parking brake and brake caliper on the drivers side. Replace 30 year old parts and no issues since then.
5. Stock clock doesn't work - probably never will.
6. Developed a pinhole leak in my modified 280Z radiator. Had it repaired and no issues with it since then BUT
7. Had to replace my LS1 thermostat because solder from the radiator repair got in it and screwed it up.
