Help with leaky R200
ihiryu
Hey guys, I've been working on my suspension in my 76.  I took out the stub axles, and realized that after reinstalling it, I've got a leak coming from the right side stub.  I was on rock auto to try to order the seal, but I have no idea which one it is.
Axle Shaft Seal
Differential Carrier Gasket
Differential Pinion Repair Sleeve
Differential Pinion Seal
Differential Repair Sleeve
Differential Seal
Differential Side Cover Seal
I'm pretty sure it's not a bearing, CV Joint Boot, Flange, so I've removed them from the list.  Axle Shaft seal, and Differential Side Cover Seal sounds right though.
