Bernardd Posted May 1, 2002 Share Posted May 1, 2002 I've changed the head on my 83 turbo from a 90a to a 90 and I can't get the sprocket up to cam. Is the P90 taller? Just checking before I take out the rad, fan and front cover to see what is going on. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 1, 2002 Share Posted May 1, 2002 Did you keep tension on the chain the whole time it as off the cam sprocket? If not, most likely your chain tensioner popped out, and you need to remove the front cover to replace it. Been there, done that. Quote Link to comment Share on other sites More sharing options...
David K Posted May 4, 2002 Share Posted May 4, 2002 Timing chain? "been there done that". lol havent we all? Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 6, 2002 Share Posted May 6, 2002 If you did not stake the timing chain, you are in for a treat. There used to be a tensioner offered that had a sheet metal limiter so the tensioner would not pop out, and I swore i was going to buy one, the next time i rebuilt an engine, but that was 4 or 5 engines ago. Sorry to be in agreement with the rest of the guys, but I think your tensioner popped out. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2002 Share Posted May 14, 2002 ......oooooooooooooooooooooooooooh.....s Quote Link to comment Share on other sites More sharing options...
