what could cause an axle to pop out
bigbreak_2000
On a 280zx with (non CV) how easy is it for one of the rear axles to work its way out of the diff if the c clip in the differential is missing?  What driving or road condition could cause the axle to slip out? Unless the car actually goes airborne is it possible that a shaft can pop out?
I found that both clips on my car axles are missing, and want to drive the car till I have the appointment to take it into the shop so they can install the clips (and new seals). I recently had a Quaife LSD installed and apparantly the guy who installed the diff did not know he needed, or forgot, to transfer the clips from the stock diff over, and Quaife diffs dont come pre-installed with the clips. Quaife recommends one secure the cips on the shaft before you push the shaft into the diff. After the first few days of driving I noticed the car had a very small oil drip when parked in the garage. It is lowered so I could not crawl under to see if the diff cover seal was leaking or if it was bleeding from overfill. When I finaly got the car on the lift at the shop we saw that the oil was actually leaking out the side of the diff and one of the axles was partly pulled out by about 2 inches. Axles on both sides are loose enough we can move them in/out by hand. I am drving extra careful now, slow speeds, wide turns, avoiding bumps and dips in the road where possible. Just curious to know what conditions could cause the shaft to move out.
The rubber boots on the u-joint halfshafts pull the ends together.  A u-joint halfshafts natural state is on the short side so there will always be a force pulling the axle out of the diff.  As opposed to the CV shafts which have a spring inside extending it.
Another thing to consider is the portion of the axle that the bearing rides on.  There's about an extra inch inside where the bearing rides.  The axle necks down to the splines.  If the axle moves too far you won't have bearing support.  Which will put a lot of potentially damaging load on your Quaife unit.
Edited by NewZed
Maybe it's the boot then.  My 280ZX CV axles take a lot of pressure to fully compress.  I haven't had them apart and didn't dig in to what keeps them extended.  It's extraneous to the OP's problem anyway, shouldn't have added it.  But thanks for clarifying.
It seems to me that you have invested a fair amount of money into your diff lately, why would you want to risk damaging it unless you absolutely had too? The only place I would drive it was back to the shop that didn't put the circlips back in. It is kind of a pain to get them in but they really need to be there.
Just experienced the snap ring thing.  My racing buddy had cross shaft wear which let his spider gears bind, sheared off about 6 spider gear teeth, locked one side of the diff then destroyed a halfshaft u-joint and wiped out the halfshaft yoke on the differential end.  At least that's what appears to have happened.  Well, to help get him back on the track, I opened up a 3.70 that I had robbed of the CLSD carrier about a year ago and swapped in an open R200 carrier, torqued the ring gear and carrier yokes with locktite and installed new seals.  Went to install his stub axles, and what do you know (?) the axle retention snap ring inside my 3.70 diff was missing on one side (argh!).  The stub slipped in and out with ease.  We robbed one out of his wrecked diff using flat head screwdrivers and then started wrestling the snap ring into my diff.  After about an hour of wrestling with screwdrivers and needle nose plyers, I recalled a post on this site that described using a socket to get the snap ring started into the carrier.  A 24mm socket (with an extension and a couple taps of a hammer) was perfect for getting the snap started down the splines squarely, then we used the stub axle and a hammer to carefully advance the snap ring into the groove inside the carrier.  Perfect.  Glad I live on this site!   Thanks hybridz!  Now I gotta find him a driver side halfshaft.
