Avernier Posted March 27, 2014 Share Posted March 27, 2014 Duh!!! You're running 15% larger injectors with no tune! Quit! You're washing your cylinder walls. Quote Link to comment Share on other sites More sharing options...
grayson260z Posted March 27, 2014 Share Posted March 27, 2014 my buddy has two VVT-I 1j swapped cressida's that he daily drives and says he gets pretty good mileage if he stays out of boost. I don't have any specific numbers but he usually only puts $10 on 93 octane at the pump and it usually lasts him about half a day and thats with occasional pulls and drifting. So if you can resist getting into the good part of you JZ engine you should be good. Quote Link to comment Share on other sites More sharing options...
Avernier Posted March 27, 2014 Share Posted March 27, 2014 Who's your buddy? Im pretty involved in the cressida world. 2vvti swapped cressidas is a rarity. Quote Link to comment Share on other sites More sharing options...
grayson260z Posted March 27, 2014 Share Posted March 27, 2014 I'll PM it to you I probably would'nt want my name on a website lol. But he has an x7 and an x8 both with VVT-I 1j's one has a w59 tacoma transmission and the x8 has the almight R154. He dd's and drifts the x7 and the x8 is solely drifitng Quote Link to comment Share on other sites More sharing options...
John1jz Posted August 7, 2014 Share Posted August 7, 2014 I get great mileage from my 1j. I've been running the car on the road for over 3 years now and keep squeezing more power from it but the mpg doesn't seam to change. I get about 32mpg on a run if I keep the speed below 80mph. I drive to spa every year (330 miles) and get there on a tank without a problem. Car weights 1284kg and make 392hp at the fly with the only mod being cams. Standard ecu, injectors, and turbos. I've also run a few 11.2's @ 131mph with a little shot of nos. these engines are superb on fuel if you don't mess around with them too much. Quote Link to comment Share on other sites More sharing options...
devil280Z Posted August 18, 2014 Author Share Posted August 18, 2014 Awesome! Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Meph Posted August 19, 2014 Share Posted August 19, 2014 I've gotten 41 MPG with my 1JZ 240z, with an r154 and 3,54 diff. This was the absolute max cruising the back roads on a 400 km stretch of a road trip. I usually fill up around 34 MPG using it to drive to work, and got about 36-37 driving across the country this year. (These are US mpg) Running stock engine with a Holset Hy35, Haltech ECU and cruising AFR of about 16:1 and pretty advanced timing (30-40) Quote Link to comment Share on other sites More sharing options...
devil280Z Posted September 9, 2014 Author Share Posted September 9, 2014 Wow that's awesome. I will definitely be happy with high 20's or low 30's!! Quote Link to comment Share on other sites More sharing options...
John1jz Posted February 22, 2015 Share Posted February 22, 2015 I've been running my 240 with soarer 1jz for over 3 years now. Car is not really a daily driver but I do drive it to all trackdays, drag racing, and car events. I always get over 30mpg if I stick to around 80mph on the motorways. Pretty standard engine on factory everything apart from boost. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted February 22, 2015 Share Posted February 22, 2015 I've been running my 240 with soarer 1jz for over 3 years now. Car is not really a daily driver but I do drive it to all trackdays, drag racing, and car events. I always get over 30mpg if I stick to around 80mph on the motorways. Pretty standard engine on factory everything apart from boost. Just curious what octane level of fuel you have available there? I just bought a 2jzgte from an Aristo and am in the process of sourcing E-85 fuel components. Here in California we only have garbage 91 octane available. Quote Link to comment Share on other sites More sharing options...
grayson260z Posted February 23, 2015 Share Posted February 23, 2015 I'm glad this thread is still going on as I advance in my swap. I don't recall seeing anyone in here running a 2jzge na-t as I will be. My plans are a stock 2jz (injectors, ecu, the works) for now and a HX35/40 turbo. I'm not building the car for efficiency but if it could do better than my ls400 I would have a reason to daily the racecar Quote Link to comment Share on other sites More sharing options...
