240sx TB install going very nice....so far
David K
ok guys i have a 240sx 60mm throttle body that i am installing on my l28 which requires me to port the manifold and make a custom 1"spacer to clear the #1 runner on the manifold. its going very good, ive done most of what needs to be done.
now my biggest concern is getting the TPS that goes on the TB. Do you guys know if this is the TPS thats on the sentra as well? if it is, does anyone have them?
TIA
dk
i filed and cut many parts on my TB. first off , i used the shaft from the 280zx TB. i filed with a very thin file the extra amount it would take to slide the 60mm plate in there. i also got the screws to fit and hold the plate in the TB.
next i went to work filing the outer part of the 240 TB so it wont hit the intake manifold. Keep in mind that i used the 280zx shaft so it would not go the extra length and hit the #1 runner on the manifold. i will post pics of my TB tommorow.
