6 Piston Wilwoods Installed Pics
slownrusty
Just recently installed Arizona Z Car 6 piston calipers on the front. Very straight forward installation and this was a complete kit with stainless new brake lines.  Bleeding was straight forward and did not even take that long.
The data:
The stock cast caliper is 12lbs, the 6 piston Wilwood with the bracket is: 2.5lbs
The Wilwood rotor with the aluminum hat is 310mm in diameter and weighs about 16lbs (about 6lbs more than the stock rotor)
I have not really tested the increased braking ability as I am waiting for the pads to bed in but will report back.
Pics.
Stock
Yasin
  • Like 1
Ooops I just noticed I posted this in the wrong forum section.
Thanks Tamo
Blu - I will definitely upgrade the rear when I have some time to figure out how to make the e-brake work, I know Dave from Arizona Z Car is working on a solution to use the factory e-brake.
I am still running RBRs - "Correct", these Wilwoods are the "narrow" model, the only 6 piston that will work with the RBR.
Regards,
Yasin
