wtb turbo stuff
Turbo72-240
You can use your stock wiring harness and dist for your turbo install. Just take it apart and fill in the centrifical advance slots halfway, have them welded, jb-weld them, or rtv'd. You can do that if the engine your using has dished pistons.
For the later 82 83 flat top piston engine lock the centrifical advance up so it doesn't move at all. Fill in the slots the same way, or lock the weights. I did this on my n/a turbo install and it worked very well for 3 years. When i had the money to upgrade my setup i bought megasquirt and a larger turbo.
I have a turbo oil feed line with the engine block fitting and the turbo oil feed fitting. I also have the T3 turbo oil drain pipe.
This topic is now closed to further replies.
