240zip Posted February 4, 2014 Share Posted February 4, 2014 When putting a L28ET into a 240Z chassis - does the new (swapped) engine use a cable throttle or does it use the old bell-crank rod and linkage setup? Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted February 5, 2014 Share Posted February 5, 2014 I used linkage in the beginning. An L28et is linkage anyway. You may have to mix and match depending on your current setup. Quote Link to comment Share on other sites More sharing options...
cgsheen Posted February 5, 2014 Share Posted February 5, 2014 Ya, this depends on the throttle body and how it's set up. The stock L28ET throttle body is linkage - just like every other Z. Some people replace them with a newer and/or larger throttle body that uses cable. Quote Link to comment Share on other sites More sharing options...
