Looking for a coil spring solution other than coilovers
Do you mean sag?
The only way to really get rid of it with your given setup, without getting adjustable height suspension, would be to buy an aftermarket or stock spring and cut away at the fronts or add a rubber cushion in the rear to raise it up.
http://forums.hybridz.org/topic/88025-installing-tokico-280z-hp-springs-in-a-240z/
^There's an example of how to even out your springs using a little thought.
Alternatively you can experiment with using a 240z top hat up front for the lower height.
God Forbid the thought of Datsun Parts in old stock... Has anybody tried that?
My favorite remedy is to take 2+2 springs and cut coils. You don't sag. But it's not a stock spring rate...muahahaha!
Custom Wound Springs are not difficult to get either.
Edited by Tony D
