Do I realy need a R200?
6inline
For a N/A L28, I would do a subi 3.90 LSD, betamotorsports, or equivalent conversion stubs and stock u-joint axles with new u-joints. You will have new stuff with low miles that is up to the task. Cheap, easy, adequate. And if you get that much hp out of an L28 I will buy you a beer.
  • 1 year later...
Thank you all for the answers. I will probably go for an aftermarket Lsd bolt on into my R180. I am not a drag guy.
I need new half shaft U-Joint. I order 4 from the local partstore. 30$ eah, MOOGs U-Joint. Did not fit. I could not slide the E-clip back. So as I compare my original with the MOOGs, I notice the MOOGs were a little larger than my original. So now I dont realy know where to get good ones. If I remember correctly the originals were 56 mm.
Anyone encounter this before me?
thanks a lot again, this forum is so helpfull!
Did you get propeller shaft u-joints, or half-shaft u-joints?  They're different.  Post the MOOG part number,
Half shaft u joints. The moog did not fit because they were a .100 too large, I could not fit the E clip. I remember my original are 56mm from top to top. The moog were like 57mm... I dont have the part number anymore, I already have brought them back.
