Yoak - 240z
MG 3809
MG 3808
MG 3778
MG 3773
MG 3770
MG 3769
I had to re do a section...with the cold temperatures I had some issues with pain curing...this despite run a jet heater and having the temperature in the 80s..
Pictures Taken January 2015
Edited by Yoak
  • Replies 97
MG 3826
MG 3821
MG 3820
MG 3816
MG 3815
MG 3814
Continued work on the rear hatch area...and some pictures of some of my first welds on the Z. I am brand new to welding so the process was interesting as I was now doing it for real.
Pictures Taken: January 2014
  • 4 weeks later...
Thanks for the compliment, I try to get as much detail as I can as you never know when you need to look back on something. I can't tell you how many times I reflect on something and go wonder what I was thinking..this helps that process.
No, I did not use POR15 - I had considered it and ended up going with what I can get locally. I used a zinc based paint...which was fairly difficult to get off even with my blaster. I think do a layer of rustoluem bedliner (same as I used in wheel wells).  The liner has a fine texture to it, similar to some to some of the ripple powder coatings I have seen. This was something I picked up from my jeep days and it generally held up pretty well in those condition so it just carried over.
  • 5 weeks later...
MG 4319
MG 4321
MG 4328
MG 4332
Floor Prep work continues...I have removed the seat bracket and the frame rail is going to go (being replaced anyway).
Because of the amount of rust I had to cut quite a bit of flooring out of the car The section near the drivers feat is going to be rather interesting to fix.
Pictures Taken April 2014
http://www.doitinadatsun.com/yoak/2015/05/240-floor-prep-continued/
MG 4366
MG 4364
MG 4353
MG 4361
MG 4346
MG 4350
This engine was going into the 240z project but will be going into the 280ZX as the 240 has a long ways to go before it will be on the road again.
Notice some of the interesting repairs done by a previous owner, especially the socket on the valve cover. As a result, I am going to be doing a complete rebuild on the engine which is a nice change all the body work I have been doing on the 240.
Pictures taken April 2015
  • 4 weeks later...
MG 4613
MG 4610
MG 4606
MG 4604
MG 4605
Pictures of what would turn out to be a bad block. Luckily I had a spare sitting around for a future build so this won't put me to far behind but I will need one for the 240Z rebuild.
Pictures taken in May.
Z8A0870
Z8A0877
Z8A0878
Z8A0884
Early install pictures of my new frame rails from Z Man of Washington.
My welds are going to win any words, but the tail is solid. In fact it is one of the things I wish I had left alone. I went back and tried to clean it up a bit and made it uglier (future pictures)...oh well as a rookie welder this is how you learn :)
Pictures Taken in June
  • 3 weeks later...
