Mismatched head and block - which gasket
rick240zed
Please don't tell me to search - as you will see, I have. And the answers vary and contradict.
I would like people to provide explanations for the answer, and not just a vote.
Here are some, match the head posts:
http://forums.hybridz.org/topic/93164-preparing-78-280z-for-turbo-swap-reusing-stock-block/?p=878887
http://forums.hybridz.org/topic/68264-which-head-gasket-l24-p90-turbo/?p=642230
http://forums.hybridz.org/topic/68264-which-head-gasket-l24-p90-turbo/?p=642327
http://forums.hybridz.org/topic/68917-p90-head-on-a-77-block/?p=1105677
Here are some match the block posts:
http://forums.hybridz.org/topic/92946-putting-p90head-on-a-75-280z-block/?p=877438
http://forums.hybridz.org/topic/70335-n47-head-on-a-flat-top-l28/?p=665985
http://forums.hybridz.org/topic/66997-felpro-head-gasket-question/?p=669237
http://forums.hybridz.org/topic/47953-wrong-headgasket/?p=413493
http://forums.hybridz.org/topic/105907-p90-head-on-n42-block-na/?p=990794
http://forums.hybridz.org/topic/102185-shaving-p90-head/?p=956811
http://forums.hybridz.org/topic/66997-felpro-head-gasket-question/?p=629556
Here are some that talk about gaskets with extra holes:
http://forums.hybridz.org/topic/101675-head-gasket-confusion/?p=952624
http://forums.hybridz.org/topic/98875-90mm-gasket-coolant-holes/?p=929474
And here's one from TonyD saying to machine block and head to whatever gasket you have:
http://forums.hybridz.org/topic/101675-head-gasket-confusion/?p=953209
So what is the real answer, and why? Please, if you don't know why, don't post and wait for someone to come with an explanation.
Also, is it less relevant on a lower power street car (my application)?
Coolant flows from the block to the head.  The gasket would be designed to control and balance flow in to the head, I would think.  So if all of the holes in to the head are open, you're good, the gasket can do its job.  Seems like the gasket that matches the head would be the way to go.  If there are holes in to the head that don't have a matching hole from the block then that's where working on the block to give the head what it needs might matter. I haven't seen where anyone's done that but maybe it happens.
