Guest TKR514 Posted December 9, 2002 Share Posted December 9, 2002 Newbie question: I'm removing the L6 from the 280ZX soon. Do I need the Nissan srecommended engine stand that bolts to the side of the L6 OR can I use a regular engine stand that supports the L6 only from the rear? It's a long engine... I did not know if it can be safely supported ONLY from the transmission boltholes without undue stress or allow bending/twisting of the block during re-assembly. Thanks for any info! Quote Link to comment Share on other sites More sharing options...
Guest TKR514 Posted December 9, 2002 Share Posted December 9, 2002 Better stated, does supporting only the rear of the engine induce a "hook" or bend in the engine that is a bad thing when reinstalling the head or manifolds? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 9, 2002 Share Posted December 9, 2002 You should be able to fabricate and adapt an L6 engine attachment to a heavy duty wide four (4) wheel based engine stand. The engine adapter should be made out of 3/8 inch plate or possibly you can still purchase the engine attachment(sto 5340001) from Nissan. Quote Link to comment Share on other sites More sharing options...
Guest TKR514 Posted December 9, 2002 Share Posted December 9, 2002 Thanks. So the side attach is the way to go. Well crud, I guess that I'll have to track down a 5340001 since I don't have a way to fabricate one. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 9, 2002 Share Posted December 9, 2002 TKR... Wait for some more responses to this question. The L6 may require side mounting due to the load 'stress' bellhousing mounting could cause. One way is to bell house mount on a regular engine stand and only install short block parts: crank,rods and pistons, oil pan and then everything else with engine in car. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted December 9, 2002 Share Posted December 9, 2002 I have supported all of the L-engines I have done from the back of the block w/o any problems. Quote Link to comment Share on other sites More sharing options...
Jeff Posted December 9, 2002 Share Posted December 9, 2002 My L6 with manifolds and carbs still attached has been on a four wheel engine stand for over two years now. It is mounted to the bellhousing bolt holes with the arms that came with the stand. I don't see any reason to purchase a special stand. I got mine off eBay and it is a basic heavy duty stand. Just my $0.02 though. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 10, 2002 Share Posted December 10, 2002 I too have had a few L6's on on the cheap 3 wheeled stands with turbo and manifolds and no problems. Make sure to get the center of the rotating mount of the stand as high as you can on the motor, it will make it alot easier to rotate. Don't line up the center of the mount with the center of the crank, or lower. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 10, 2002 Share Posted December 10, 2002 Fellows: Keep in mund that the 3 wheeled engine stands are a lttle unstable and can tip over like the old tricycles we used to ride. I have both but feel more comfortable moving or turning an engine on a 4 wheel stand Quote Link to comment Share on other sites More sharing options...
Guest TKR514 Posted December 10, 2002 Share Posted December 10, 2002 I called our local Nissan folks... They "don't sell parts". I guess the next step is to try the .Net supply houses for the L6 fixture.... Quote Link to comment Share on other sites More sharing options...
katman Posted December 10, 2002 Share Posted December 10, 2002 Originally posted by TKR514:Better stated, does supporting only the rear of the engine induce a "hook" or bend in the engine that is a bad thing when reinstalling the head or manifolds? Nope. Regular stand, engine supported from the back, no problemo. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 10, 2002 Share Posted December 10, 2002 I've seen ppl used the holes for motor mount to hold the motor side way before. But I've my engine on stand with four head bolts in the beall housing holes. Quote Link to comment Share on other sites More sharing options...
