need BOV, L28et, p90, t3/t4,oil/coolant feed,engine/tranny mounts,shifter bushings,ms3,gauges,
jomz shakes
I have a 1982 280zx n/a that I'm converting.
I need a bov, I like the greddy type s but open to others.
L28et with p90 head. Built or non built.
T3/t04e hybrid turbo, with gaskets/mount spacers for turbo
Oil feed line and what ever I need for a coolant feed line
New engine and tranny mounts
Shifter bushings
Megasquirt package w wideband
Set of same color gauges
Intercooler piping
Heat wrap/heat shields/turbo blankets
High output oil pump
Stainless steel lines for Everything
Clutch/brake fluid master cylinder
Clutch slave cylinder
Stage 2/3 clutch kit
Spoiler and front air dam
Hid projectors
Roll cage bucket seat and harness
Steering wheel and hub
LSD nismo or quaife
Please call or text 650 867 5567
Or post back and I may have you send pictures.
I have a L28et/T5 (p90A) .. entire motor cleaned up, brand new gasket kit and rear main seal installed, metal head gasket, arp studs, new clutch, head completely cleaned up. I also have a MS3 unit wired for it, im not exactly sure if the megasquirt is for sell yet.
