Drift Boss Posted January 4, 2015 Share Posted January 4, 2015 Hey guys, long time no see, but i do troll on here as everyone does. Here is my Datsun 280z! I bought it for the shell mainly. I loved driving around the Ford 302...but it wasn't the engine platform i preferred. So.. BUILD First thing i did was remove the good awful huge 280 bumpers, and rear louvers. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 4, 2015 Author Share Posted January 4, 2015 Next thing, replacing the mirrors... Much better... Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 4, 2015 Author Share Posted January 4, 2015 The 302 made 280WHP. Mods Trick flow allu. heads 202 valves Custom cam Custom push rods T5 bw trans Ac! No power steering Roller rockers Hydrolic lifters Elbroke intake and carb Forged flat top pistons Prettt much every bolt on known to man. Only made 280... Quote Link to comment Share on other sites More sharing options...
dexter72 Posted January 4, 2015 Share Posted January 4, 2015 Do you have the Toyota setup already??... Im just about ready to do my 2J Swap. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 4, 2015 Author Share Posted January 4, 2015 Yeah, i do. Its a 1jzgte, i converted to single. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 4, 2015 Author Share Posted January 4, 2015 Mines already in, just have to catch this build up to date Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 5, 2015 Author Share Posted January 5, 2015 Engine Rebuilt trans gettete r154 Quote Link to comment Share on other sites More sharing options...
TheSaturnV Posted January 5, 2015 Share Posted January 5, 2015 Reminder of how GodAwful 280z bumpers are. Lookin' great! Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted January 5, 2015 Share Posted January 5, 2015 Drift Boss, Have any pics of the mounting for the engine and trans? and where did you get your engine from? I am about to go 2jzgte and am researching engine importers and mounting options. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 5, 2015 Author Share Posted January 5, 2015 I just made my own mounts. Very easy to do. I used 1/4 steel. 4x1/4, i believe you can get a 20 foot long peice from any steel supplier for about $70 I will go over my mounts in detail soon! Dallas jdm or something like that. they are in Dallas texas. I do have a rear sump oil pan, i am welling to sell. Oil line kit drift motion Egay wastegate Clutch! Flywheel with arp bolts Drift motion manifold Garrett ball bearing turbo Downpipe kit (DM) Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 5, 2015 Author Share Posted January 5, 2015 So since they dont sell 1jzgte middle intake gaskets...i made my own. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 5, 2015 Author Share Posted January 5, 2015 And... Throttle body gasket Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted January 6, 2015 Share Posted January 6, 2015 Nice parts there. So far the parts I have for my build are a rear sump pan and components from an SC300 and a barely broken in (1700 mile) Marlin Crawler built R154 trans with a Spec twin disc clutch. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Well damn! That's better parts then what i started with! My pan is also from a sc300. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Refinished the intake manifold Removed these... Line install Plug Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Fitment issuess (for me) Ac has to go... Most mount kits run their trans mounts of this...i had to cut it out...it hits my trans. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Next up...mounts! I went and bought a 220volt welder. Lincoln seems to be the great brand. I have owned 3 lincoln units before, none gave me any trouble. These are the EASIEST mounts i have ever made. I have done countless rb mounts/1j/2jz 240sx setups.... All you need is the 1/4 x 4 inch flat steel, and one peice of 1/8 x 1 inch flat steel. Cut the mount plate on side of engine, drill 4x holes. Then cut 9.75 inch long of flat steel. Then cut braces for the sides, make sure you set them in and tack weld before you fully weld them. Pretty much a 90 degree design. Keep in mind k am.not a professional welder lol.. No gas weld! Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Now, i added 1/8 steel angle iron to the frame rails,and YES there is a rubber mount between the frame and mount. Also, the holes are drilled threw the rear subframe, so you know it has a very strong bolting area. Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Setting in the bay, bolted up. Trans fitment. I have to get soarer shifter Quote Link to comment Share on other sites More sharing options...
Drift Boss Posted January 6, 2015 Author Share Posted January 6, 2015 Now i am cought up. Next i am going to try to do the trans mount. Wish me luck! Quote Link to comment Share on other sites More sharing options...
