Ah, i miss driving it.
I guess i could give everyone a run down whats already been done.
New frame rails 1/4 inch thick
Tundra front 4 piston caliper conversion
Wilwood porportion valve
Rear disk conversion
Custom cv axles rear
r200 rear end
Del sol seats, recovered
New carpet
Dash pad
Custom cut bullet specialties wheels 17x10, 17x9
Lowering springs (soon to be coils)
Rear zg flares
Refinished paint about 4 years ago.
I will post some pics off all this stuff!
Welcome to the addiction, its good to see some more Oklahoma people on here. I have seen you car on the OKZCC FB page and can not wait to see it get finished up and out out some of out track days. Keep up the great work you are making good progress and if you need any advice this place is great. Hope to see you around!
Will S.
Here is the previous brake upgrades.
Anyway.
Here is some updates. I bought new mounts after seeing a ls1 swap had crushed his frame
Only problem is..i have to weld in new mounting pads to my stock subframe :-( as the 302 guy cut them out when the 302 was put in.
Repainted the twin pipes
Welded up the holes i drilled
Sanding!
Touched it up with some base for a artist to come out and do his thing on the engine bay :-)
Reloomed until my fingers hurt
Also relocated that ugly starter relay thing off the firewall, to inside the car.
So. I installed my flares today.
Aluminum 1/4x20 rivnuts (24 of them)
Rubber GM welting (25ft roll)
Ace Hardwire 1/4 x20 machine screws, finishing washers, and, rubber washers.
Rivnut installer tool (lol)
Tapped up the flare exactly where i wanted it, then drilled a 1/4 hole threw the flare, hitting the medal behind it. It will leave a mark in the medal so you know exactly where to drill.
Then you pull it off and start drilling (step up your size drill bits) you want to have a 13/32h hole end the end.
Used my handy rivnut tool. This is why i used alu. Rivnuts. Mine all came out prefect.
Install rubber welting, as you see fit. Not rocket surgery.
Bolt it all up.
