ThatOneZ Posted April 15, 2015 Share Posted April 15, 2015 (edited) I just ordered a new set of wheels for my 75 280z they are 17x9 with +20mm offset, i was wondering what kind of spacers i would need. i was thinking one inch spacers for the rear but i cant figure out what to do with the front. I also heard there was a hub bore size difference between the front and the rear. Edited April 17, 2015 by RB26powered74zcar vague title Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted April 15, 2015 Share Posted April 15, 2015 Spacers will probably correct the hub bore because they're going to be so large. If you're on stock suspension then you need at least 4.5" of backspace. you wheels are 10" wide lip to lip, and at +20 that leaves you with more at about 6.25" of backspace. So it'll be more like a 1.5" spacer Why did you buy these wheels? Quote Link to comment Share on other sites More sharing options...
ThatOneZ Posted April 15, 2015 Author Share Posted April 15, 2015 On 4/15/2015 at 7:27 PM, BluDestiny said: Spacers will probably correct the hub bore because they're going to be so large. If you're on stock suspension then you need at least 4.5" of backspace. you wheels are 10" wide lip to lip, and at +20 that leaves you with more at about 6.25" of backspace. So it'll be more like a 1.5" spacer Why did you buy these wheels? I don't quite understand what you're saying, why would I need 1.5" spacer instead of a 1"? Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted April 16, 2015 Share Posted April 16, 2015 (edited) I'll soon be in the same boat with my 17x8 +22 wheels. What is your suspension setup? If you're on stock sized springs you'll run into clearance issues on the front spring perch with a +20. You need around a +0 in a x9 (I think) to clear the spring perch. So a 1" spacer should do the trick. I mocked up my x8's and with a +22 they JUST cleared the stock suspension setup; way closer than you'd ever want to run because they had a piece of paper width between the lip and the strut tube. And you couldn't mount a tire on it because of the spring perch. So I'll be running 1" or 1.5" spacers with my setup. You can reverse calculate from there I'm sure. Thing to watch out for on the front is the hub bore. Its 73mm. Most wheel spacers are 66mm. Just make sure you get a spacer with at least a 73mm centerbore. I think the largest I've seen them with before was 78mm and 81mm. Edited April 16, 2015 by R3VO 3VOM Quote Link to comment Share on other sites More sharing options...
ThatOneZ Posted April 17, 2015 Author Share Posted April 17, 2015 On 4/16/2015 at 7:55 PM, R3VO 3VOM said: I'll soon be in the same boat with my 17x8 +22 wheels. What is your suspension setup? If you're on stock sized springs you'll run into clearance issues on the front spring perch with a +20. You need around a +0 in a x9 (I think) to clear the spring perch. So a 1" spacer should do the trick. I mocked up my x8's and with a +22 they JUST cleared the stock suspension setup; way closer than you'd ever want to run because they had a piece of paper width between the lip and the strut tube. And you couldn't mount a tire on it because of the spring perch. So I'll be running 1" or 1.5" spacers with my setup. You can reverse calculate from there I'm sure. Thing to watch out for on the front is the hub bore. Its 73mm. Most wheel spacers are 66mm. Just make sure you get a spacer with at least a 73mm centerbore. I think the largest I've seen them with before was 78mm and 81mm. Thanks for clearing things I think I'll go with 1.5" spacers all around Quote Link to comment Share on other sites More sharing options...
jaguargt Posted April 24, 2015 Share Posted April 24, 2015 Did you finally install your wheels? pics? Thanks Quote Link to comment Share on other sites More sharing options...
ThatOneZ Posted May 2, 2015 Author Share Posted May 2, 2015 On 4/24/2015 at 1:49 PM, jaguargt said: Did you finally install your wheels? pics? Thanks Yep here are some pictures Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 4, 2015 Share Posted May 4, 2015 That looks great! Quote Link to comment Share on other sites More sharing options...
zelociraptor Posted May 13, 2015 Share Posted May 13, 2015 Do you have any pictures from the back or side? Quote Link to comment Share on other sites More sharing options...
willee24 Posted October 14, 2015 Share Posted October 14, 2015 Could you tell me where you got your spacers? I am also getting some str wheels with the same size and offset. Also, what tires did you get and suspension all stock? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
