My Turbo LSX Z31 Builld
nismo kid
Figured I might as remove all unwanted wires from each of the factory wiring harnesses. Each terminated wire was properly depinned from the connector. Armed with the Z31 FSM I identified & labelled all connectors. The label maker I used is the Dymo Rhino 5200. It's hands down the best label maker I've ever used/owned.
Chassis Harness
Before
  • post-1999-0-54183600-1476208442_thumb.jp
  • post-1999-0-06424600-1476208448_thumb.jp
Out of curiosity I weighed the all terminated wires. It weighed in at 10.4 Lbs exactly. To be honest it wasn't worth the 60+hrs I spent terminating, labelling, & reworking the harnesses. I also replaced all factory loom & re-wrapped all the harness with fire resistant electrical tape. I could've done it faster but even if it only took 30 Hrs, it would still be too much in my opinion.
  • post-1999-0-95666600-1476208705_thumb.jp
  • post-1999-0-21296700-1476208711_thumb.jp
Seemed like the perfect time to remove majority of the sound deadening. Considering everything inside the cabin removed. I've removed my fair share of sound deadening out of several different vehicles over the years. I've found dry ice to be the fastest, easiest, & cleanest. The dry ice method leaves minimal amount of residue. The only downside is dry ice is kinda pricey. But well worth it in my opinion. I also like to use maximum strength Goo Gone to remove all left over residue. It literally wipes off after letting it soak 5 minutes. Here's some pics of sound deadening removal process.
Before
  • post-1999-0-57862500-1476208900_thumb.jp
  • post-1999-0-14463800-1476208908_thumb.jp
  • post-1999-0-62625800-1476208919_thumb.jp
  • post-1999-0-00986600-1476208924_thumb.jp
The speedo cable leaked terribly. It heavily saturated the firewall sound deadening. Just the firewall sound deadening I removed weighed in at 18.1 Lbs! I was shocked to say the least.
Here's some pics of the gear oil that was leaked everywhere.
  • post-1999-0-49936900-1476209096_thumb.jp
  • post-1999-0-91577500-1476209099_thumb.jp
  • post-1999-0-20738100-1476209103_thumb.jp
  • post-1999-0-70782600-1476209356_thumb.jp
  • post-1999-0-53143100-1476209359_thumb.jp
  • post-1999-0-85263900-1476209363_thumb.jp
Moving on I finally got my hot side of the turbo kit cermic coated. It's a shame to cover those fantastic welds but, it's for the greater good. Shot a quick pic when I dropped it off. Ignore the parts under the red x. They're not mine.
  • post-1999-0-32532600-1476209527_thumb.jp
