Dipstick Relocation Clarity
~KnuckleDuster~
I need some clarification on relocating the dip stick to accommodate the rear sump pan. We removed the brass plug from the rear dipstick hole and the dipstick tube is slightly larger than this (rear) hole. I'm getting mixed information on this topic. Does this hole need to be drilled out and tapped or is it supposed to just swap right over? If it does need to be drilled and tapped wouldn't it be easier to get a reducer fitting and just re-adjust the fill lines on the stick?
I've got the dang pan installed and motors in the car and somehow glossed over the whole dipstick relocation thing!
