melma! Posted November 20, 2015 Share Posted November 20, 2015 Hey question for you guys that might have better searching skills Than me... Â Can you do a blowthrough turbo setup on su's? Â I know if you use mg Metro carbs you can push a supercharger through them, however I'm looking for a more discreet power boost... Â I was thinking maybe welding up the factory air cleaner box and plumina the turbo through the front? Â Any thoughts? Quote Link to comment Share on other sites More sharing options...
melma! Posted November 20, 2015 Author Share Posted November 20, 2015 Oops plumbing* Quote Link to comment Share on other sites More sharing options...
veritech-z Posted November 20, 2015 Share Posted November 20, 2015 http://www.triumphexp.com/article/how-to-blow-through-an-su.html Quote Link to comment Share on other sites More sharing options...
melma! Posted November 21, 2015 Author Share Posted November 21, 2015 I guess I already found that oops... Â I was looking more for an idea of how to set it up... Â Do you think using the factory air cleaner box would work? Quote Link to comment Share on other sites More sharing options...
veritech-z Posted December 16, 2015 Share Posted December 16, 2015 If you seal it well enough, I'd imagine it will hold boost if that's what you're asking. Â What's the goal of the project? From some of the comments in your initial post, it kind of sounds like you're trying to build a sleeper, but maybe you're just looking to add a turbo to your otherwise stock setup to keep costs low? Just curious, and I think it affects the suggestions you may get. This thread I thought was interesting along the lines of keeping an SU look but going TBI:Â http://forums.hybridz.org/topic/85654-su-fuel-injection-manifold-conversion/ Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted December 8, 2020 Share Posted December 8, 2020 Wet blanket 😕 ...  I don’t recommend it. Based on many posts from the early 2000’s, most folks got frustrated and went with FI ultimately. Getting A/F ratio right on a turbo setup is by far the most important aspect of tuning Due to the risk of detonation. SU’s are a constant-velocity carb that forces intake restriction to achieve this goal. Those that were marginally successful swapped out to a supercharger-ready down-draft carb but were still plagued with tuning issues.  this was popular way back in the 70’s-80’s before tunable FI systems became ubiquitous.    Quote Link to comment Share on other sites More sharing options...
tobilemons Posted March 17, 2021 Share Posted March 17, 2021 I agree with above. Quote Link to comment Share on other sites More sharing options...
zboi Posted August 22, 2023 Share Posted August 22, 2023 You would need to get some external ignition box to do boost retard. Probably easiest to go 4 barrel intake and a factory blow thru carb. Quote Link to comment Share on other sites More sharing options...
