bent frame rail
encycloware
i had a mechanic to come over and look a 280zx
and he said he needed to jack it up to look under the car
and he jacked it up on the frame rail on the driver's side - this would ringht under - drivers floor board area
and I bent down and watched this and saw the frame rail bending so i told him to stop
well his jack bent in the bottom of rail - about  1/4 of an inch  or a liittle more and left some marks on the rail - the side of the hollwo rial appear to be still solid and the
the bend is about 4 inches long - it's basically an impression from his jack
he never lifted the tires off the ground -
if he was going to jack this way - he should have used wood to maybe
the rest of the upper rail appears straight and level  - only the bottom part next to the ground appears
bent in and not level with the rest of the rail
i did notice tha the door of the car seend to shut tighter - after this - but maybe that is just me noticeing things all of a sudden
my question - should i be concerned about damage to the car - saefty wise -
thank you for any assiatance
i will try to take a picture and show you tomorrow
Bent frame rail won't be a catastrophic issue safety wise, most z cars (240z-280zx) have probably a wrinkled frame rail from years of jacking.
Yes he probably should have used a bit of wood to spread out the surface area or just use the pinch welds.
Even so, the frame rail should have been able to take quite a bit of weight before caving or denting, I suspect maybe some rust is present there, and if there is a large amount of rust this could be a cause of concern.
i appreciate the advice - more than you know -
I told him to jack at the pich wield - but he said he knew waht he was doing -
and then he bends it -
i think he would have done more damage if he had continued - his intent was to cawl under the car
so i stoped his job and decided to have it towed to a shop to be worked on -
i guess it is possible the car could have fallen on him
he did not break the metal - it's like he bent in the sqaure shape rail at the bottom - bent it out of shape with the end of his jack -
it looked like the jack was bending the hollow rail before it could even lift the car
I do not see any rust in this area - even after the bend
i have no idea how to inspect inside the rail
after this incident I looked under the car on the other side and I did notice a rust spot at the end of the other rail on the passenger's side near the rear -
so maybe  water has collected inside to of these sqaure rails over time
I have a rust problem at the rear of the car from tailpipe exhaust over the years
I'd like to find a good way to stop this rust - but I think I going to need a rear panel around the lisence plate
If at some point the rails need to be replaced -- is there some source on this
that someone can recommend -
i have a 280zx 83 coup - orginal owner -
130,000 miles
it needs body work and new paint job
I have used this product from Eastwood Automotive in every opening I could get the nozzle into in an attempt to stop any rust it would cover.
http://www.amazon.com/Eastwood-Internal-Coating-Prevention-Nozzle/dp/B003NTPE9W/ref=sr_1_2?ie=UTF8&qid=1448861405&sr=8-2&keywords=eastwood+internal+frame
As you and I well know (born and raised most of my life in NC), you are in the rust belt.
Here is Eastwood's video for product application.
I moved away from NC back in '95, but still visit friends and family every year so not sure on body work other than this company in Wilmington (National Speed), who did an incredible job on the lime green 240z awhile back.
http://nationalspeedinc.com/
 I might be able to come up with a few shops around Raleigh, Cary area after asking friends living there.
