dream240z Posted May 5, 2016 Share Posted May 5, 2016 Dropping in an l28et with t5 trans into my 1970 240z my first engine swap, anyone in the Olympia area wanna help? Quote Link to comment Share on other sites More sharing options...
cgsheen Posted May 5, 2016 Share Posted May 5, 2016 Best of Luck with the swap! Quote Link to comment Share on other sites More sharing options...
Equizyme Posted May 5, 2016 Share Posted May 5, 2016 when are you planning on doing it? I live north of seattle but i wouldn't mind taking a trip down to give a hand. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted May 5, 2016 Share Posted May 5, 2016 Could be fun. Bit of a drive though. If you get replacement mounts you are going to need to drill for the locating pin, they are cast off on the 2 or 3 companies I have dealt with. Quote Link to comment Share on other sites More sharing options...
NW240Z Posted May 5, 2016 Share Posted May 5, 2016 Your location says Seattle, the car in Olympia though? I live near Centralia and could come and help some too. I ask the same question as Equizyme, when were you planning on doing the swap? Quote Link to comment Share on other sites More sharing options...
seattlejester Posted May 6, 2016 Share Posted May 6, 2016 That is a pet peeve, but the last guy I met goes to school in seattle and had his car stored elsewhere. I noticed that this is your first swap. Do you even have all the parts? I think you need to space the trans cross member, did you already get it modified? You need the engine brackets from the stock motor, you need the T5 drive shaft, possibly shortened, high pressure fuel pump, wiring for fuel pump, both wiring harnesses. Quote Link to comment Share on other sites More sharing options...
