cdl1542 Posted May 18, 2016 Share Posted May 18, 2016 Hi all, My clutch won't engage or disengage and I can't seem to figure out the issue. It's a 280zx 5 speed transmission, dual center force clutch, has the 280zx slave cylinder as well. Lines are bled properly, new slave cylinder installed and bled. It seems as thought the slave cylinder will not move the fork which is leading me to think its the throw out bearing but I would appreciate any insight on the topic. Thanks! Chris Quote Link to comment Share on other sites More sharing options...
supernova_6969 Posted May 19, 2016 Share Posted May 19, 2016 have you tried removing (like unbolt and move it aside) the slave cyl and engaging/disengaging the clutch by hand with an assistant that tries to shift gears at the same time? it might be hard (should be really, with a new clutch plate) but if you can disengage teh clutch, shift and re-engage the clutch manually, then that might indicate that that part is working. also, doing that, you might be able to have someone gently press the clutch to see the slave cylinder's action. I don't knwo how it's supposed to work, but I'd go gentle to make certain you don't shoot the piston right out of there. not much of a solution, but it might help you figure out where the problem lies. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 19, 2016 Share Posted May 19, 2016 On 5/18/2016 at 11:35 PM, cdl1542 said: My clutch won't engage or disengage You have to pick one. The only way to fit your words is that the clutch is in a state of constant slippage. Is this a new problem on a system that was working fine? Or is it a bunch of new parts that aren't working right? Quote Link to comment Share on other sites More sharing options...
cdl1542 Posted May 19, 2016 Author Share Posted May 19, 2016 On 5/19/2016 at 12:38 AM, NewZed said: You have to pick one. The only way to fit your words is that the clutch is in a state of constant slippage. Is this a new problem on a system that was working fine? Or is it a bunch of new parts that aren't working right? The best way I can put it is that I can shift through the gears when the car is off, but the clutch pedal doesn't seem to be doing anything. It's not a new problem from a working system, it's new parts together that don't want to work. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 19, 2016 Share Posted May 19, 2016 Search "wrong clutch collar" or "wrong TOB" or "transmission grinds" or "92 mm" and you'll figure it out. Did you match the TOB collar to the pressure plate? That's the most important act when installing a new clutch. Quote Link to comment Share on other sites More sharing options...
