Austing Posted May 19, 2016 Share Posted May 19, 2016 So I'm redoing gaskets on l28 and I had it marked at tdc before I pulled head after wards I looked and saw that two valves are open numbers 4 and 5 the rest are closed. Does this mean my valves need to be adjusted with feeler or is that normal? It not open like crazy just a little open like 2 cm. Quote Link to comment Share on other sites More sharing options...
rjracin240 Posted May 19, 2016 Share Posted May 19, 2016 Just took the 510 out to run it this year after being laid up for the last 3 years, went to turn over the motor and find that I get a 1/4 revolution on it and it is locked up on either side of the revolution. Guessing I have some valves also hanging up. First time I have ever had a issue with Datsun motor like this. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 19, 2016 Share Posted May 19, 2016 On 5/19/2016 at 2:26 PM, Austing said: saw that two valves are open numbers 4 and 5 the rest are closed. Ponder a complete set of combustion events (two revolutions) and you'll realize that there are always valves open. Look closer and you'll probably see that there are more than just two open. Quote Link to comment Share on other sites More sharing options...
Austing Posted May 19, 2016 Author Share Posted May 19, 2016 Thank you new zed I was worrying about that if that maybe be a underlying issue or a serious issue waiting to happen. Also I don't get why I can't positive up a post it says I reached my quota even tho I've never been able to positive vote before. Quote Link to comment Share on other sites More sharing options...
Leon Posted May 19, 2016 Share Posted May 19, 2016 On 5/19/2016 at 2:26 PM, Austing said: So I'm redoing gaskets on l28 and I had it marked at tdc before I pulled head after wards I looked and saw that two valves are open numbers 4 and 5 the rest are closed. Does this mean my valves need to be adjusted with feeler or is that normal? It not open like crazy just a little open like 2 cm. 2 cm would be an absolutely HUGE opening in terms of valve lift. Quote Link to comment Share on other sites More sharing options...
