280z dash rebuild new idea
walkerbk
Beware of the stuff that will vaporize from whatever you're using, when the inside of the car gets really hot.  It will redeposit on your windows.  You'll be cleaning the windshield every other day if you get the wrong materials.
Many paints and caulks and filling compounds use plasticizers to make them soft and/or spreadable.
It is very similar to the stock weight, maybe a few ounces heavier. When I pull the passenger side one I will get a weight difference. Before I finished filling everything in with foam, the screw that attaches it to the metal arm can be adjusted for more or less tention adjusting the amount of tension it takes to pull it down. I just set it where I liked it and filled over the screw with foam for a nice clean look.
