RebekahsZ Posted October 21, 2016 Share Posted October 21, 2016 My diff has been whining for 25 years. Quote Link to comment Share on other sites More sharing options...
chiefmd Posted October 23, 2016 Author Share Posted October 23, 2016 Well got it disassembled today and guess what I found. Inner pinion bearing was "trashed". Outer ball bearing also needs replacing as it does have some rough spots when rotated. Will keep you posted. 1 Quote Link to comment Share on other sites More sharing options...
heavy85 Posted October 25, 2016 Share Posted October 25, 2016 Yep looks familiar Quote Link to comment Share on other sites More sharing options...
chiefmd Posted November 5, 2016 Author Share Posted November 5, 2016 Got the diff all back together today. Tightened down the pinion nut per Jon's instructions. My question is how much force should it take to rotate the pinion. I put a electronic torque wrench on it and it takes about 35 lbs to rotate the pinion shaft. The FSM state about 20 lbs. Should I back off the pinion nut a little? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 5, 2016 Share Posted November 5, 2016 Pinion nut torque shouldn't change the torque to spin the pinion. The resistance comes from the distance between the two tapered roller bearings. If you have significantly more resistance than that, the most likely cause is the pinion seal dragging on the pinion flange. Did you grease it? Did you seat the ball bearing and the seal all the way? Quote Link to comment Share on other sites More sharing options...
chiefmd Posted November 5, 2016 Author Share Posted November 5, 2016 Jon - Thanks for the input. I pulled the pinion flange a greased the seal. All is good. Thanks again. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 6, 2016 Share Posted November 6, 2016 Any time! Glad to hear it worked out. Quote Link to comment Share on other sites More sharing options...
