JelmerPatrol Posted March 3, 2017 Share Posted March 3, 2017 Short and large diameter runner are for HP and small, long runners for torque I believe. These are long and large runners, so best of both worlds? Still, the flange doesn't fit the head..... What If you cut it off behind the flange and weld a EFI flange on it with the injector bosses and port it to match the diesel runners, would this be a good low down torque manifold? I'm asking because I have a L28 in my heavy Nissan Patrol which could use more low down torque. I'm going turbo with it and want as much torque as possible (already have a P90 head, RB20 turbocharger, flat top pistons) Quote Link to comment Share on other sites More sharing options...
Chickenman Posted March 3, 2017 Share Posted March 3, 2017 (edited) ^ I was just thinking along the same lines as JP. 1: First the current injector position has to go. It is just wrong . You can buy weld on universal injector bungs and easily position the injectors in the right position on the manifold. Factory EFI designs and angles are a good starting point. You want the spray pattern to hit the backside of the intake valve . Right in the center of the valve is a good starting point. 2: Cut the " J " turn out of the manifold. Leave as much of a straight leg as you can on the flange side and the plenum side. Then weld the two sections together. Basically you should now have shorter runners with a larger diameter ( than the Factory NA EFI runners ) that allows a straight shot into the cylinder head. Win Win. Of couirse Plenum is now rotated 90 degrees, so you may have to reposition the TB flange, if it not a symmetrical square flange. With these modifications, particularly the injector boss re-location, you will have something interesting to test that will at least work. Look around the internet and you will find successful and proven high performance Plenum manifold designs that all have similar characteristics. Key points are: A: Injector placement as close to intake valve as possible. B: Proper plenum design. This can be very tricky, especially on Turbo engines. What looks right can be terrible from an actual distribution of air flow. There are some basics to follow, but using a pre-made factory or Custom plenum is a not a bad idea. Unless you have $100,000 or so of CFD computers and air flow testing equipment sitting in your basement C: Runners as straight as possible. No unnecessary bends to slow down airflow. Velocity is important even in a dry manifold. Some gentle bends may be seen in some of these manifolds, but that is only to facilitate port entry angle and hood clearance. Here are some pictures picture of proven designs for Audi/VW 1.8 5 Turbo engines. NA version is virtually identical. A good design for a NA engine will also be good for a Turbo engine, and vica versa. SEM manifold: 034 Motorsports manifold Edited March 3, 2017 by Chickenman Quote Link to comment Share on other sites More sharing options...
Chickenman Posted March 3, 2017 Share Posted March 3, 2017 (edited) These should give OP some basics as to good overall designs. Pay attention to injector placement and plenum design. You don't need the flashy CF and anodized finish to make something decent. Here is a picture of an SEM manifold next to the stock VW/Audi manifold. Runner sizing on VW/Audi engines is more than large enough stock ( We have 5 valve per cylinder engines ). Most of the improvements come on the Plenum side. Plenum is too small on the stock manifold. Stock manifolds does not have a very well balanced airflow to cylinders either. Custom Plenums produce some of the finest aftermarket manifold in the world. Very highly regarded in the Motorsport world. Check out the 2JZ-GTE manifold on their FB page for some design ideas for the L28. Yes thye do supply L28 manifolds as well. These are $$$$$: https://www.facebook.com/customplenumcreations SRDE20 Manifold Edited March 3, 2017 by Chickenman Quote Link to comment Share on other sites More sharing options...
JelmerPatrol Posted March 3, 2017 Share Posted March 3, 2017 That is what I had in my BMW but with ITB's: Quote Link to comment Share on other sites More sharing options...
Chickenman Posted March 3, 2017 Share Posted March 3, 2017 ^ Very nice. Are those Manometers on the firewall? Checking individual port flow or balance? Quote Link to comment Share on other sites More sharing options...
JelmerPatrol Posted March 5, 2017 Share Posted March 5, 2017 Yes manometers for balancing. Quote Link to comment Share on other sites More sharing options...
ol doc gully Posted March 9, 2017 Share Posted March 9, 2017 (edited) Short and large diameter runner are for HP and small, long runners for torque I believe. These are long and large runners, so best of both worlds? Still, the flange doesn't fit the head..... What If you cut it off behind the flange and weld a EFI flange on it with the injector bosses and port it to match the diesel runners, would this be a good low down torque manifold? I'm asking because I have a L28 in my heavy Nissan Patrol which could use more low down torque. I'm going turbo with it and want as much torque as possible (already have a P90 head, RB20 turbocharger, flat top pistons) the main/easy correlation is with length - short runners for high rpm performance, long runners for low rpm performance. this has to do with benefits from tuning for pressure waves as much as actual flow. diameter has to do with velocity and so is more of a dependent variable based on other design factors. i like the idea of this manifold for a mild/street turbo application though. long runners for good low rpm response and boost for high rpm. i think the runners are still a bit long for that though, so i think you're idea of welding a plenum to the lower section is great. but whats teh point of any of this if the flange doesnt fit? ^ I was just thinking along the same lines as JP. 1: First the current injector position has to go. It is just wrong . You can buy weld on universal injector bungs and easily position the injectors in the right position on the manifold. Factory EFI designs and angles are a good starting point. You want the spray pattern to hit the backside of the intake valve . Right in the center of the valve is a good starting point. 2: Cut the " J " turn out of the manifold. Leave as much of a straight leg as you can on the flange side and the plenum side. Then weld the two sections together. Basically you should now have shorter runners with a larger diameter ( than the Factory NA EFI runners ) that allows a straight shot into the cylinder head. Win Win. Of couirse Plenum is now rotated 90 degrees, so you may have to reposition the TB flange, if it not a symmetrical square flange. With these modifications, particularly the injector boss re-location, you will have something interesting to test that will at least work. Look around the internet and you will find successful and proven high performance Plenum manifold designs that all have similar characteristics. Key points are: A: Injector placement as close to intake valve as possible. B: Proper plenum design. This can be very tricky, especially on Turbo engines. What looks right can be terrible from an actual distribution of air flow. There are some basics to follow, but using a pre-made factory or Custom plenum is a not a bad idea. Unless you have $100,000 or so of CFD computers and air flow testing equipment sitting in your basement C: Runners as straight as possible. No unnecessary bends to slow down airflow. Velocity is important even in a dry manifold. Some gentle bends may be seen in some of these manifolds, but that is only to facilitate port entry angle and hood clearance. Here are some pictures picture of proven designs for Audi/VW 1.8 5 Turbo engines. NA version is virtually identical. A good design for a NA engine will also be good for a Turbo engine, and vica versa. SEM manifold: 034 Motorsports manifold i agree but a few pesky clarifications aftermarket manifolds are entirely built for high boost/high rpm - thats why they look like they do. doesnt mean they should be used as a guide for intake manifold design and doesnt mean they are right for everyone. for instance, factory RB manifolds look a lot like the diesel manifold being criticised here (pictures below) also i entirely agree that the injector placement in the proposed manifold is... far from ideal. seems to be a convenience factor based on where the original flange was. but FYI the common practice of injector placement at the head is actually primarily to help with emissions (esp cold start) but the goal is just getting a well homogenized/atomized mixture in the chamber and there are other alternatives. Edited March 9, 2017 by ol doc gully Quote Link to comment Share on other sites More sharing options...
