mrk3cobra Posted September 26, 2017 Share Posted September 26, 2017 I installed an after market Tilton clutch master cylinder, you can see in the picture the rod from the master cylinder does not line up with the clutch pedal. The rod is offset by about 3/4". The 240Z was missing the master cylinder, so I did not see how it was connected. How does the rod connect to the clutch pedal? Quote Link to comment Share on other sites More sharing options...
ZHoob2004 Posted September 26, 2017 Share Posted September 26, 2017 I'm having a hard time seeing any alignment/misalignment in the picture. The master cylinder should be directly inline with the pedal left/right, and should be pretty close to one of the holes in the pedal up/down. Here's a picture of the connection I lifted from atlanticz Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted September 26, 2017 Author Share Posted September 26, 2017 If you look at the picture the clutch rod is 3/4" to the left of the clutch pedal. I will try and take a better picture. Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted September 26, 2017 Author Share Posted September 26, 2017 Quote Link to comment Share on other sites More sharing options...
Namor Posted September 26, 2017 Share Posted September 26, 2017 I don't remember running into any issues when I installed my pedal assembly/master cylinder but I have a 280z and it appears as though there are slight differences. If you look here, it looks like their pedal has a bracket welded to the pedal to correct the offset. http://www.jdmjunkies.ch/wordpress/2015-10-28/240z-pedal-box-throttle-pedal-assembly/ I noticed the same thing in a few other pictures. And if you read this thread, it sounds like the same issue you have as a result of trying to use a 280z pedal in a 240z pedal box. Quote Link to comment Share on other sites More sharing options...
cgsheen Posted September 26, 2017 Share Posted September 26, 2017 1 hour ago, mrk3cobra said: This picture is of a "late" clutch pedal - used in a 260Z and 280Z. The 240Z clutch pedal was different - made of thinner steel and curved along it's length to add strength. At some point (1973ish...) the brake booster was changed and a larger booster was used. The clutch master was moved farther away from the brake master due to the larger diameter of the new booster. The pedal box and clutch pedal changed also. Looks like you need an actual 240Z clutch pedal. Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted October 3, 2017 Author Share Posted October 3, 2017 here is my solution. Pete Quote Link to comment Share on other sites More sharing options...
