smelllikefumes Posted October 13, 2017 Share Posted October 13, 2017 So about a week ago my car started to have issues when it got up to temp. It would originally start, idle, and run fine, but after the car began to get warm it would lean out like crazy (have a wideband installed) and there would be no response when throttle was applied under load. It did this for a few days until it decided to completely die on my way home from the gym. After a few minutes the car would start and idle lean on the side of the road, but then die immediately with any throttle (not under load). The engine is from a 1983 280zx turbo. After a little bit of research I'm wondering if it is my Crank Angle Sensor in my distributor, but I'm still very confused. I don't think it's a wet Throttle Position Sensor because I had that problem recently and I removed it/dried it out and the car ran fine. Also the symptoms are different due to not even idling rather than failing at 2000rpm. Short video with symptoms: https://streamable.com/nn9ls Quote Link to comment Share on other sites More sharing options...
