Electronic boost gauge on L28ET simple?
I've been doing hours of research and have decided to get a boost gauge for my 280z with L28ET turbo swap. The problem is, I don't really like the look of any of the mechanical gauges.
I really like the Speedhut one where you can "Design your own" and has an LED warning light: http://www.speedhut.com/gauge/GR-BOOST-01/1/Boost-Vac-Gauge-30inhg-0-20psi-(w--warning)
I called and they said this was an electronic gauge. I know that installing a mechanical one is easy, but is an electronic boost gauge just as simple?
It looks like speedhut supplies you with a pressure sensor and sensor wiring harness. It seems like you would just tap into the vacuum line with the T fitting, plug in the pressure sensor to the t-fitting, and run their sensor wiring harness to your gauge instead of a vacuum line like you would for a mechanical one. Is this correct?
Edited by AlbatrossCafe
