Ordering some wheels, 16x8 or 16x8.5 for rolled fenders?
I believe the popular panasport set is the 16x7 +10. Seems a bit conservative. I've looked into sizing for this stuff obsessively and most people seem to be having the best success with 16x8 +4 on some of the rota sets. I wouldn't try to run any wider without a higher positive offset.
Also refer to this thread
With 2.5 inch spring like TTT coilovers have you can run a little bit more inboard I think the springs are 4 inch od vs the 5.75 inch stock perch (my memory might be fuzzy). I know another size that is run is 16x9+0, but a 16x8.5+30 is the equivalent of say a 16x9.75+0 (in regards to inboard), which may be a bit much.
For that price I would just get a wheel gauge or make one yourself to make sure before purchasing. I suppose worst case you could run extended studs and slip on a spacer.
I have two 240Z's both running 16 x 8" CCW's with 16" / 245  / 45 series tires, both cars have coilovers and rolled fenders with no problems.  It is best to get one of those measuring tools or go to a shop with one to get the right offset for your specific suspension.  You should try to measure it so you do not need to add a spacer.
Edited by primaz
