Tachometer connection
rk2334
Hi everyone,
I have swapped rb20 into 280zx 1983turbo. The stock speedometer was straight forward mechanical outputs, but I don’t know how to modify stock tachometer to take a rb20 signal .
Any advice is appreciated as always
What engine management system are you using?  If it uses a single coil to spark all cylinders then just running a wire from the coil's negative terminal to the tach should work, just like the 83 ZX uses.
The diagrams are in the electrical chapter of the FSM.  Circuit Diagrams.
