inline6 Posted June 21, 2018 Share Posted June 21, 2018 (edited) How is this possible? This car on eBay, was made in 1/71 according to the door tag, but has VIN HLS30-14751. My car's tag has 12/70 and the VIN is HLS30-16511. Here is my VIN plate (unfortunately partially sandblasted by a prior owner): Can someone explain? Did this car on eBay get held up in production - set aside for a bit? Anyone else ever hear or confirm this occurred at all with this period of Datsun's? Also, the Zhome registry has lots of VINs that are close to mine more or less with regard to production date. And here are two VINs from the Zhome registry which sandwich the VIN of the car on eBay - both show 11/70 production dates: Garrett Edited June 22, 2018 by inline6 Added Image Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 22, 2018 Share Posted June 22, 2018 I've seen the odd Z with a VIN that doesn't quite match its build date. That one isn't all that far off. I don't really know for sure, but yeah, I'm guessing it got held up for some reason. Someone more knowledgeable can confirm, or correct me. Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 23, 2018 Share Posted June 23, 2018 VINs are not necessarily sequential in the first year of production, there were times where chassis were put back on the line after 'sitting on the side' for whatever reason was repaired and then went forward with production and completion. I had a car in Japan, S30-110661 which was an early car (No Center Console, Blanked radio and Clock, No Chrome Trim Window rubbers, 240 Dash, Tail Lights, with 100L Fuel Tank Option only offered in the early models) It's the only one that late I have ever found, most are 260-Pattern Chassis starting at S30-108XXX, and this jibes with the official production records maintained by Nissan as well. THAT is a quandary, much more so than an early number having a later production date. A later VIN having earlier characteristics smacks of 'special build'... Quote Link to comment Share on other sites More sharing options...
