mforget Posted July 22, 2018 Share Posted July 22, 2018 Hi, i just tried to install my steering rod on my build using cxracing complete swap kit, seems like the rod hits the left side engine mount preventing me from bolting the steering rod upper coupler. I will have to modify the engine mount to make the rod clear. Just wanted to know if anyone else ran into this problem. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted July 22, 2018 Share Posted July 22, 2018 Mine was close but fit.... old Datsuns can “sag”...... you may have to shim the mounts. HTH Jim Quote Link to comment Share on other sites More sharing options...
walkerbk Posted July 23, 2018 Share Posted July 23, 2018 Mine was close as well but fit... try bolting it all together loosely and then check fitment. Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted July 23, 2018 Share Posted July 23, 2018 I had to notch the mount a small amount for the shaft to clear. HTH, Richard. Quote Link to comment Share on other sites More sharing options...
mforget Posted August 31, 2018 Author Share Posted August 31, 2018 On 7/23/2018 at 7:07 PM, Richard Oben said: I had to notch the mount a small amount for the shaft to clear. HTH, Richard. Expand Same for me.....Thanks for the help! Quote Link to comment Share on other sites More sharing options...
walkerbk Posted September 2, 2018 Share Posted September 2, 2018 Looking back at mine it has worn a nice ring around the shaft. So I think I'm going to end up notching mine after all. Quote Link to comment Share on other sites More sharing options...
