bradyzq Posted March 5, 2019 Share Posted March 5, 2019 Those are crank degrees. So swapping leads around won't help. According to msextra.com you should be ok at zero, running in "next cylinder" mode. http://www.msextra.com/doc/ms1extra/MS_Extra_Ignition_Hardware_Manual.htm#MSnS How about the physical position of the rotor to the pin on the cap? Maybe it's firing off the edge of the rotor. I would suggest lining the rotor up so that the rotor is pointing directly at the pin on the cap with the engine at about 30Deg BTDC. That way, your entire operating range of 15-45 degrees-ish, is as far away from the corners of the rotor as can be. Quote Link to comment Share on other sites More sharing options...
bradyzq Posted March 5, 2019 Share Posted March 5, 2019 BTW, good job on your YouTube channel. I subbed. Quote Link to comment Share on other sites More sharing options...
Neubs Posted March 15, 2019 Author Share Posted March 15, 2019 On 3/6/2019 at 9:54 AM, bradyzq said: BTW, good job on your YouTube channel. I subbed. Cheers! It’s nice to get feedback and I hope you enjoy the content. Quote Link to comment Share on other sites More sharing options...
Neubs Posted March 15, 2019 Author Share Posted March 15, 2019 What started as a bleed of the brakes has evolved into a brake system rebuild. As long as I can remember the right drum brake cylinder bleed nipple has been sheared off at the base. It’s one of those things that I’ve know about but never actioned fobbing off to do it next time. No excuses now. Time to fix it. The end game brake goal for this car is a set of Sumitomo MK63 font calipers to retain the standard master cylinder. Not sure if vented or solid rotor. I guess this will be dependant on what’s available. I’m not in a rush to get a pair and considering it is likely to come from Japan I’ll wait until a good deal surfaces. I’ve have a spare pair of Sumitomo S16 cailpers and rebuild kits plus brake pads to cover off on the fronts. The rear drum brake cylinders look new so I’ll get some rebuild kits for those. The master cylinder I will remove and send away to be stainless steel sleeve which should make it good for life. I am bummed that tuning is on hold but it is important to have road worthy car. Quote Link to comment Share on other sites More sharing options...
Neubs Posted March 21, 2019 Author Share Posted March 21, 2019 I was going through my spares and came across some distributors from the Nissan RB30 motor. The RB30 SOHC motor is common in Australia used in the mid to late 80s and internally seems to be similar to all the distributor based ignitions at the time produced by Nissan. 280ZX turbo otipical dizzies are rare as hens teeth in Australia. I thought this would be a good substitute. I have a 12-1 replacement chopper disc from DIYAutoTune to replace the 360 slot standard one which could allow my to convert from the MSD unit to COP. Before I let my enthusiasm get the better of me I decided to check a few things first. Datsun 240Z L28 stroker – fitting an RB30 distributor - part 1 Quote Link to comment Share on other sites More sharing options...
Neubs Posted April 7, 2019 Author Share Posted April 7, 2019 Back to rebuilding the brake system this week. I decided to stick with drums on the rear. Having made that decision both the rear brake cylinders and brake MC will be sleeved to last longer than I will. So the rear brake cylinders and MC came out easy enough. The left side brake cylinder is properly frozen, not even the adjuster nut came out with ‘hammer time’ persuasion. I thought that I’d need to get new rear cylinders but after a chat with chap (after the youtube video was made) who will be handling the sleeving, the sleeving workshop can get anything apart. So rear brakes and MC have been posted away. I’m looking forward to the results! Quote Link to comment Share on other sites More sharing options...
Neubs Posted August 31, 2019 Author Share Posted August 31, 2019 Its been a while since my last post about this car. The brakes have been rebuilt. You can see those videos on the channel. In summary for the brakes: • Rear drum cylinders and MC were sent to South Coast Brake Resleevers • The MC was stuffed but the resleevers had a NOS MC lying around so I got that which I’m chuffed about! • Rear drum cylinders were resleeved to a high quality cause they were shagged • I rebuilt the front calipers myself So the brakes are on and bleed but I have not go little red off the blocks just yet. I really want to use the optical dizzy that Gav240z from the AusZCar forums gifted me (these are like rocking hose poo in Australia!). I had one big cost hang up that ultimately determine if I used the optical dizzy or used a CAS from One Six Industries and wastes spark and that was the turbo oil pump drive. Nissan dealerships and Nissan Australia parts had not had one in stock for over 20 years. Getting one from somewhere the US was pushing upwards of $200USD. I was getting sad. Lucky enough I came across a new product post from Kameari Raceworks who had decided to make there own when the genuine item price increased. The Kameari unit cost ¥11,000 which was heaps cheaper than any other pump drive and delivery wasn’t a lot from Japan to Australian. I put my order in and it turned up pretty quickly. So project optical distributor has commenced in full! See the video here: Quote Link to comment Share on other sites More sharing options...
Neubs Posted September 19, 2019 Author Share Posted September 19, 2019 Its always frustrating when things don’t go to plan. All the parts arrived to rebuild the distributor much faster than what I was advised and I had the dizzy housing PBM blasted and scrubbed to a raw appearance. I really like to look of the housing. I’m still hesitant to commmit to swapping the oil pump drive shaft to the turbo shaft until I know for certain that this dizzy works. So the dizzy was put back together and mock wired to the Megasquirt for an RPM signal simulation. No dice. Didn’t work. Nothing. I suspect the new crank angle sensor is not a functioning unit but will require more investigation. So looks like another few weeks without tuning the ignition for the car unless I put the old Pertronix L24 distributor back in. All I want to see is if I can crack 200rwhp on SU carbs.... Quote Link to comment Share on other sites More sharing options...
Neubs Posted October 18, 2019 Author Share Posted October 18, 2019 I bit of perseverance (and a new CAS haha) has paid off! I have a functioning L20ET distributor that my Megasquirt MS1 can read. I fiddled with a few mods to the board taken from a few sites that have V3.0 board info. Ultimately I could have left the mods at removal of C12, C30, D1 and D2 but I left one of the diodes in as backflow protection. I didn’t need a pull up resistor but I left the one I had installed from the S12c pad. The Fuelmiser crank angle sensor Sparebox first sent was faulty through bench testing. Sparebox quickly replaced it which was great. I slapped the dizzy back together with the DYIAutoTune 12-1 trigger wheel which means I can run COP later if I choose. The next step for me is to swap in the turbo oil pump drive with the engine in the car. It’s the one item of work I have been putting off for obvious reasons haha! Quote Link to comment Share on other sites More sharing options...
Neubs Posted March 16, 2020 Author Share Posted March 16, 2020 Hey all. A bit of time has past since my last post. Not a lot has progressed on the 240Z. Only a bit of refinement with the ignition map on the Megasquirt really. I’m almost happy enough to hit the same dyno to see if my tweaks pay off. I have had the suggestion of swapping out the SB needles to TF needles which I am contemplating but I want more logged data to inform my choice. With the time away from working on the car it has given me time to think. I’ve decided to convert to EFI. I’m excited to be working with Whitley Tune as a guinea pig for a future ‘Sports Injection’ kit for the L6. I’ve got a 3D printed test runner, throttle body and trumpet to clearance in the car. End to end it’s 410mm based on a third harmonic of approximately 5500 rpm. It is suitable for a second harmonic of approximately 7700rpm but I doubt building a head for that is in my capability but I might swap cam and work a head to be as efficient as possible for the third harmonic. Throttle bodies are Ø50mm straight bore butterfly. Have a look at the video below to get a feel for the runners, they’re a lot bigger in real life. The Megasquirt MS1 is pretty underpowered and can manage two banks of batch fire injectors at best. I will wire a bank of injectors corresponding with the banks of primary runners from my Zstory exhaust manifold using dual WBO2 to run closed loop target AFR maps. Ignition will remain as the 12-1 trigger disc L20ET distributor with MSD 6AL. I may change to COP at a later stage as an experiment but for now, if it isn’t broke don’t fix it. I am at a cross road for fuel supply. I have a Bosch 050 I had planned to use in conjunction with a surge tank and existing Holley Red as a lift pump. I have seen a few in tank EFI pump options. Has anyone used an aftermarket in tank pump? I’m interested in any experiences. The tank will come out for rehabilitation anyway. https://youtu.be/WtZvR__CQ3Q Quote Link to comment Share on other sites More sharing options...
Neubs Posted April 12, 2020 Author Share Posted April 12, 2020 So, stock 4 screw round tops can support at least 201.6rwhp. There may be some debate over how the dyno calculates hp but there is a decent increase from the last dyno in hp and torque from essentially a tune to the fuel and ignition. Tune is super rich which could be fixed with different needles like TF but I wanted to get a run in in case QLD requires a lock down to manage the pandemic. I’m super chuffed. When I set out to home build the L28 stroker motor all I wanted as 200RWHP with triple Webers. To think I could achieve that with the standard carbs is amazing! I’ve attached the 2017 dyno sheet and the 2020 sheet. I can now get back to the ITB EFI swap knowing that it is likely to only make more power! Quote Link to comment Share on other sites More sharing options...
Neubs Posted April 12, 2020 Author Share Posted April 12, 2020 1 Quote Link to comment Share on other sites More sharing options...
Neubs Posted May 7, 2020 Author Share Posted May 7, 2020 (edited) Time for some Megasquirt ECU mods! I had configured the MS1 V3 board for ignition only. Some additional work and mods are needed to make it fully armed and operational for EFI. In the process I broke a leg off one of the current resisting devices for the injector banks I will have to buy new ones from DIYautotune as they are hard to get with the hole to mount on the heatsink. Thats really all that is left to complete on the ECU. In summary I've added: second WBO2 sensor input second Nissan optical trigger input fan relay control 2 wire IAC control shifted the launch control input 5V tach output There isn't many standard configurable pins left in the DB37 harness now..... Edited May 7, 2020 by Neubs Quote Link to comment Share on other sites More sharing options...
Neubs Posted June 19, 2020 Author Share Posted June 19, 2020 A little more has happened with the EFI build. Dual lambda sensors is what! I had planned to run dual lambda sensors on the Hitachi SU carbs if I had not the opportunity to work with Whitley Tune and the sport injection setup. The goal now is two injector banks with target AFR maps. I run a Zstory 6-2-1 header and I decided to locate the sensors at the collector of the primaries to mitigate the risk of air contamination through a joint. Its probably overkill but it seems sensible to have the most accurate reading possible if I’m trying to have the most accuracy target AFR map for two banks of injectors the MS1 V3 allows me to have. Cylinder 4-6 location was easy! The collector is located in the space between the gearbox and transmission tunnel. This one was near vertical which is the optimum orientation. Cylingders 1-3 collector is tucked in behind anything and I could to find an orientation that I was happen with to manage heat for the sensor and the wiring so I located on the side of the collector. The sensor and wiring is just in front of the gearbox in the space behind the sump. Its not completely horizontal but I’m confident its still in a good location. Innovate Motorsports recommend 24” from exhaust and these are about 35”. I’ve had an LM-2 for more than ten years and I plan to install a DLG-1 if it ever gets here (understandable shipping delay). Matt welded these bad boys in (MYS30 build - not sure if he’d on HybridZ?). I am in his debt . Quote Link to comment Share on other sites More sharing options...
Neubs Posted June 19, 2020 Author Share Posted June 19, 2020 Quote Link to comment Share on other sites More sharing options...
