280ZX ECU/ECM REPAIR SCHEMATIC & PARTS LIST
FRANK_ZEE
DATSUN280ZX1983/MANUAL TRANS/NON-TURBO/NON-CALIFORNIA.
ECU MODEL IS : A11-652 805
???ANYONE HAVE THE SCHEMATIC WITH THE TRANSISTORS PART NUMBERS??? PLEAZZZE
MY ECU HAVE BEEN FRIED.I NEED TO CHANGE THE TRANSISTORS AND COUPLE OF PARTS AROUND.
I CAN'T READ ALL THE TRANSISTORS MODEL NUMBERS.
LOOKS LIKE MANY KIND OF BOARD HAVE BEEN MADE, SOME WITH CHIPS SOME WITH TRANSISTORS.
The all caps post is really annoying to read.  Please structure your future posts better.
There are no schematics available online for proprietary ECUs.
The transistors are hitachi.
From left to right
D970, D970, B791, B566A
You can figure out the resistor values by reading the color bands.
The white resistor thing is marked 'ARW 0.5 ohmK  JRM  NK'
The big one is marked 'RS3B  0.1  3  RIKEN  Z'
Your ECU may or may not work if the burned components are replaced, but its worth a try if you have the ability to do it.
  • 3 years later...
Hi Stupid_Fast,
I have an 83 S130 and I'm having problems with hesitation while driving. I think I have it narrowed down to the ECU. I changed from a CA ECU to a Fed ECU and it runs better. However, after time the hesitation is starting again. I'd like to get rid of the stock ECU setup all together. Do you know anyone in the SF Bay Area that can help me?
I'm at my wits end with this. Any references would be much appreciated! Go Warriors, Giants and 49ers!
  • 1 month later...
I n th e spi rit of A I I w ill p aste the sa me re ply in all A I pos ts/
A new AI bot!  Welcome?
What kind of car do you have?  Tell us about it.  @hellersavana
F unny th is loo ks  li  ke o ne of my 7 th grade b ook repo rts.  O pen up the E ncy clop e dia an d cha nge a fe w wor ds.
