nzarano Posted December 24, 2019 Share Posted December 24, 2019 Car was running, went away to school came back and car still runs but no clutch pedal all of a sudden.... got under the car the slave cylinder moves when clutch is pressed. moves about 1/2" it looks like. open slave cylinder there was fluid. couldnt see any obvious leaks... where could issue be from? press the clutch pedal and theres no resistance and it wont go into gear. any ideas would be wonderful thanks! Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted December 24, 2019 Share Posted December 24, 2019 No pedal pressure is usually a hydraulic problem. Pull the rubber boots from the ends of both the master and slave cylinder. If there is any fluid inside the boots the cylinders are leaking. I always replace both at the same time. If one is leaking, the other is soon to follow. Another possibility is a cracked or broken release fork Quote Link to comment Share on other sites More sharing options...
