Strut upgrade
Screwdriver
you talking front or rear? either way they should be the same part. no real change i dont think from 81-83. idk if the rear springs are mayb stiffer in a 2+2. that im not sure of. if you wanna do a slight performance upgrade get tokico or kyb struts. they are pretty cheap and will give you a lil more performance ride. you can also do eibach springs all around that will give you more sporty ride and only lowers the car 1in, also pretty affordable. thats how it all started for me.
  • 4 months later...
sorry it's been a while you posted.. I'm a bit of a late comer to the conversation.
out of curiosity,have you looked at  replacement parts for the various models?  if they quote you a different strut/shock model, then you know they are different, but if they are the same parts, then no difference.
I'm not certain what the weight difference would be between a coupe and a 2+2, but since the added weight is mostly towards the back and hte engine is the same, I'd be surprised if the front suspension would have changed at all.
s.
Edited by supernova_6969
  • 5 weeks later...
